BIKELAND > FORUMS > ZX-14.com > Thread: aluminum fan? NEW TOPIC NEW POLL POST REPLY
lawnplus
posted March 21, 2008 06:25 PM
aluminum fan?
getting ready to install brocks gen 3 pipe on my 06 zx14. Do you guys recomend the muzzy alum fan and how big of a differance in keeping it cool?
thanx plus.
200hp_zx14
posted March 21, 2008 06:32 PM
Don't need it. A waste of money if you ask me. I never had a problem with over heating and I don't think many people have.
Unless you ride in stop and go traffic in 1st or 2nd gear most of the way in 100 degree heat, don't worry about an aftermarket fan.
207HP* '06 Candy Blue ZX-14
Some mods done
Best run - 10.19@137.40mph
Bawls
re-learning to ride
posted March 21, 2008 06:33 PM
I haven't had the chance to use any in my bike yet, but I run Engine Ice in my Banshee and in my car and they both run around 10 degrees cooler. My car used to run around 200 degrees, and now it stays around 190. If anyone knows about the fan, i've been wondering the same thing myself.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
posted March 22, 2008 07:40 AM
good for hot city driving, stop and go , where the bike is ridden too slow to get much air in the rad. It will bring down temps alot quicker. moves alot more air.
I think my zx10 fender mod did more for it, ALOT more air going into rad, and fan comes on alot less.
with both mods, my bike has rarely seen more than 3-4 bars, even in 110f weather.
and high temp alert has never come on.
I have to mention that losing the cats made a massive difference too.
Sticks_n_Stones
posted March 22, 2008 07:45 AM
I've had numerous problems with it running at the top bar on the temp gauge, even though it was only 80-95 degrees outside. It only had a problem at low speeds stop light to stop light stuff, or on the freeway in stop and go. Really pissed me off that my brand new (stock at the time) bike was nearly overheating from that. For some reason certain bikes seem to run very hot... And its not a gauge issue, either. Idled it and measured with a non contact thermometer gun and fans kicked on at 210, engine hit 230 at top bar indicated.
I got the Muzzy fan now, but its only 45-55 degrees so I dont know if it helped yet. But I did notice a definite improvement when I installed my two brothers slip-ons, and then gradually as it broke it. The week after I put on the exhaust (and hit 2500 miles) it stopped hitting the high bar on the gauge. Second one downs not alot better but still...
I just wish I could install a lower temp thermal switch to engage the fans sooner! Should be around 180 or 190, no reason why they kick on at over 200 degrees. I'll let you all know when it warms up into the mid 80's at least if it worked. Sometime in June... lol
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
posted March 22, 2008 07:52 AM
to lower engine temps, listed in priority from my experience and results:
1) get rid of cats... huge improvement
2) zx10 fender, much more airflow fan hardly comes on
3) muzzy fan, when it does come on it brings temps down quicker
I also run engine ice.
and of course anyone running aftermarket exhaust needs to make sure they're a/f ratio is in check, via map. If its lean it will run hot no matter what.
200hp_zx14
posted March 22, 2008 11:05 AM
I had an 03 R1 (with a digital temp gauge) and the fan kicked on at 214 degrees and turn off at about 205 degrees. I would assume that this is normal for pretty much all bikes. I think my 14 runs a touch hotter than the R1 based off the temp bars but I don't think the fan runs any more than on the R1.
I live in one of the hotter climates in the US (southern AZ) and I think the muzzy fan is a waste of money. The only way I would see my temp gauge rise higher than one bar above the middle would be if I stopped at one of the longer lights mid summer when its about 105 or so. Even then it would only rise one more bar and still not reach the top. As soon as I'm moving it will almost instantly drop to below the middle.
Some mods done
FasterThanStink
posted March 22, 2008 11:25 AM
Some bikes run hot. My temp gauge is always at 5 bars in the city in traffic. Any improvement, even a small one would be welcome. I'm changing coolant before getting the bike out this year. I'll see if that helps.
That's what gets you.
Sticks_n_Stones
posted March 22, 2008 12:54 PM        Edited By: Sticks_n_Stones on 22 Mar 2008 13:58
Hmm. found the answer to my own question! Lots of choices that would work, I would recommend the one that just makes contact/is attached to the radiator hose. The probe thru the radiator works, but I've had them and found they always have issues over time, between the probe just going out and the connection going bad. Must be related to the wind blowing through the radiator constantly flapping the wire till it breaks all its strands.
Obviously the screw in type is the best, but good luck finding a hole to put that into on a bike.
http://store.summitracing.com/egnsearch.asp?N=700+115+%2D106362&D=%2D106362
Just run a power wire to the battery (when using the probe so it will run after shutoff until radiator cools) or to a switched source, or even better to a 2 input switch. Run a switched wire and a hot wire to it and if you want it to run after you shutdown (especially useful for drag racing) you can just flip it. Take that fan + wire and splice in the new thermal switch. easy!
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
BIGZXDADDY
posted March 23, 2008 05:11 AM
almost every engine made today runs at 210 degrees. what would the advantage be in making it run cooler?
"never drive faster than you can see, besides it's all in the reflexes"
Sticks_n_Stones
posted March 24, 2008 06:28 AM
because 210 degrees is around the prime spot for an aluminum headed and/or blocked engine to make its most EPA efficient burn. you dont get the best power at that temp, but you do get the least emissions readings there. It's a very common hot rodding trick to drop it down to 180 for iron heads and 185-195 for aluminum. Trust me, that 15-20 degree drop in operating temp is very noticeable in power, and also in radiant heat put off by the engine and engine compartment.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
Wheelie
Old Man
posted March 24, 2008 06:44 AM
if your bike has a 180 degree thermostat, it will run 180 degrees no matter what fan you have, even if you change to a water treatment, the additives make the temp rise slower and drop faster when past 180 degrees. make your hazard light switch a instant on fan switch, you can turn on the fan when you see traffic ahead or at a redlight at a push of a button.
wee
Sticks_n_Stones
posted March 24, 2008 06:57 AM
agreed with the haz light switch IF the fans wont drain the battery when the bikes at idle. Would hate to have a dead battery after driving an hour in snarled traffic, ya know?
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
Wheelie
Old Man
posted March 24, 2008 07:27 AM
I run my fan with the engine off when im in the staging lanes waiting to race. no dead battery
wee
LeoVinceZX14
Thankfully...its paid for...
posted March 24, 2008 12:53 PM
Keeping Cool...
Lawnplus:
I don't know where you a based, but I am in Florida and most everyone I know here with a 14 has seen significantly cooler running bikes once a pipe went on. I ran a Leo Vince 4-2-1 and Mobil One all through 2007 with no overheat issues in traffic, heat, humidity, whatever including alot of time in 90+ degree temps. Some of the guys here have also run Engine Ice so I guess it depends on your environment and whether you are a racer spending time in staging lanes, etc or a ton of city traffic. Good Luck.
Ride Safe...
'12 14R SE
PC V
Custom map
BMC filter
Leo Vince 4-2-1 w/ carbon can
Sato frame sliders
Supersprox 42T
Cox radiator guard
DID 530 X-ring chain.
davej
posted March 24, 2008 05:02 PM
Suspect mapping will help most of the overheating problem. After the turbo install haven't seen beyond the third bar even in one hour stop and go traffic. 2200 miles on install.
Triumph guy
Bawls
re-learning to ride
posted March 25, 2008 11:53 AM
Thank you california for legal lane sharing lol. I plan on putting a manual switch on mine, and running engine Ice. Seems like a good idea since i'll be going through TX,NM,AZ and CA in mid June *yikes*. May end up having to ride at night. I guess we'll just have to see lol. The good news is that i've got a white bike so at least it'll be a little cooler in that sense.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
NinjaNick
'08 ZX14 (Blue)
posted March 25, 2008 12:06 PM
I was riding this weekend in 30 degree weather here in Ohio and It wouldn't go above 1 bar when I was moving...lol.
On warmer days it does get 1 bar above halfway though.
ninja12
posted March 25, 2008 12:42 PM
I agree tuning can make a big difference.
Add a little fuel at idle and watch the cherry pipes go out.
pdonnell
posted March 25, 2008 07:22 PM
The muzzy fan does pull more air than the stocker. But (and as Muzzy has told me) the 14 does not have cooling issues like other bikes. Jet Hotting the headers and pipes has had more effect on the overall engine heat.
So its and improvement not necessary. But I was ordering packing for the cans anyway so I went with the fan. (and painted it the color of the bike)
davej
posted March 26, 2008 05:45 AM
I'll be installing the fan this summer when the weather hits 100+. Not because it's needed but to keep the engine as cool as possible.
Triumph guy
MasterBlaster
posted March 26, 2008 06:18 AM
Muzzy fan does pull a significant amount of air over the stocker. I have one and was a snap to install, I had no clearance problems or need to trim the fan. Probably wasnt necessary, but also doesnt hurt to have the extra capacity. Cheap insurance if othing else but to make you feel better.
bingo
posted July 03, 2010 02:00 PM
I also did this, and it made a world of difference. Although I am currently not running any fender at the moment. I was thinking about getting a secondary fan, but this might not be necessary.
I am running a Yoshimura system with Engine Ice and a Muzzy fan. haven't gone above 4 bars and rarely over 3 bars in 105 degree heat with stop and go.
edster14
posted July 08, 2010 05:18 AM
running hot
Haven't tried it yet but i have heard good things....plan on ordering some myself. if anyone has already tried it lets hear what result you have had...here is the website http://www.evanscooling.com/
Zeiraminc
posted July 08, 2010 11:32 AM
My 2009 ZX-14 ran at one bar from max on gauge in stop and go trafic, any weather condition. I purchased a used stock cooling fan on ebay for $74, installed it and wired it to the stock fan. Increased fan fuse by 5amps.
Now it runs at one bar past half way point on gauge in any weather condition, including 106 degree weather.
And the whole thing looks stock.
0.23738598823547 seconds processing time
