BIKELAND > FORUMS > ZX-14.com > Thread: Modified Kickstand NEW TOPIC NEW POLL POST REPLY
hardcoremass
Powerhouse
posted March 14, 2008 04:34 PM
Modified Kickstand
Looking to modify stock kickstand, approx how much do you need to remove to accept 64" wheelbase with muzzy links on second hole. I have noticed that there are companies producing these with 2.25" removed from stock stand, does this sound acceptable?
07 zx14 (black), flies removed, BMC race filter, Muzzys M10, PClll, PC ignition module, RT ext, Muzzy lowering links, 40 shot spray
JamesE
posted March 14, 2008 05:35 PM        Edited By: JamesE on 14 Mar 2008 18:36
I'm stock wheelbase, lowered 2nd hole Vortex and 3/4" in frt. I cut 1.25" out of mine, seems perfect. Make sure you get the angle right on the "foot" , mine kinda hits on the back corner now not flat like before. Not bad though.
07 Plasma Blue ZX 14 Flies out Tsukigi slip-ons, PCIII, -2" rear
-1" frt, Heli's, Scorpio SR500i equipped
hardcoremass
Powerhouse
posted March 14, 2008 05:36 PM
Thanks for the reply James, much appreciated!
johnnyrocketzx14
posted March 14, 2008 08:42 PM
if you strap it at the track u might want to take a bit more out (well or release your strap b4 u try to use the stand) i tool over 2"s off mine
07 ZX14
Brocks Sidewinder, Stretched, lowered, strapped,Drag seat, PCIII W/Hub, No flies, BMC, Speedo Healer, Muzzy NOS/Shifter,
1.41 60, 5.77 1/8th 8.89 1/4
  Ignore this member    Click here to visit JohnnyRocketZX14's homepage.
BobC
posted March 15, 2008 02:14 AM
I have Muzzy links and use them in the 3inches lower position. What I did was to lower the bike and then put packing pieces of wood under each wheel varying the thickness until the bike was leaning at the desired angle (with the uncut kickstand). Then, measuring the thickness of the wooden packing pieces, I cut that amount off the stand. I cut the foot off first and then cut down the stand by the required amount and welded the foot back on. Easy really and it worked a treat.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
MasterBlaster
posted March 15, 2008 05:51 AM
I cut about an inch off mine, an also where the kickstand hits the forward stop used a rotary grinder to groove the stand to fit around the stop so it will angle further forward. Now its very sturdy. Forks are slipped an inch and lowered an inch in the rear.
hardcoremass
Powerhouse
posted March 15, 2008 09:04 AM
Thanks for the replies fellas. Probably will remove approx 2" of stand.
0.2495059967041 seconds processing time
