4TEEEN
posted March 12, 2008 07:54 AM
My second 14 that is consuming oil
I am new here and wanted to see if anybody has experienced an oil consumption issue. My 06 14 was burning 1 quart every 600 miles and now I have an 07 that has burned 1 quart in 1,500 miles. Kawasaki is saying that 1 quart in 1,000 miles is acceptable. The 07 is completely stock.
4TEEEN
k bryant
Sponsor
posted March 12, 2008 07:57 AM
No that is not acceptable. Who at Kawasaki stated that ?
4TEEEN
posted March 12, 2008 08:01 AM
The dealership called Kawasaki Tech line
4TEEEN
damn, mine never burned or leaked a drop....
Sticks_n_Stones
I second that Bryant. I use less than half a quart every 1000 with combined cruising/high speed riding on my 06. Sounds like you got the infamous leaking valve cover gasket issue. Use the search function to find how to check for it and fix it.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
4TEEEN
posted March 12, 2008 08:12 AM
They checked the gasket as did I and it is not leaking. My 06 had bad rings. It did have 25K miles in just over 1 year and I do run at very high speeds but can't believe that 1quart in 1k miles is acceptable.
4TEEEN
BlackMagic14
posted March 12, 2008 08:20 AM
I agree that is unacceptable. Dubious where can we see the sig pic without the homer!!!!!
posted March 12, 2008 08:23 AM
it is not acceptable.
I would run 2000 miles between oil and tire changes, and the oil level did not appear to drop at all.
the airbox was misted a bit from highspeed extended 7-8000 rpm cannonball riding, as the crank vent was still in airbox, but I always ran oil levels to the top of the sight glass....
nitrous and aggressive riding...
I made 3000 mile twisty spirited riding trips and it averaged 7000 rpm with many many ( iw ould guess hundreds of jaunts to 10-11000 rpm and it still was 3/4 up the sight glass.
I rode the bike with average speed over 150 mph for 2 hrs once, and oil level never seemed to drop at all.
Don't get me wrong, I rode it hard but never hurt it, intentionally or otherwise.
Oh, and the kawi break in sucks.
I use moto tune method...
Sticks_n_Stones
I'm at work, and gotta keep scrolling past that damn sig pic before someone sees it! Come on Dubious, just post up a SMALLER pic! takes like 1 minute in windows paint shop to resize!
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
posted March 12, 2008 08:35 AM
ok!
LOL
dbeadling
posted March 12, 2008 10:17 AM
does not burn a drop of oil here
posted March 12, 2008 10:35 AM
man boy-howdee how many more oil threads are we going to see in here? I was the first to report, and after Kawi had my bike and attempted to repair so many times, I sold it. Heads up though, everyone makes lemons, and all the Kawi's I've had with no probs I'm not complaining. And I loved the 14!
the day after I got back from Deal's Gap I saw oil on the left fairing againand dumped it. Who knows maybe i road it harder than it could "handle" at the Gap, pics of it on the Gap ridden are here: http://www.bikeland.org/board/viewthread.php?FID=8&TID=35917&set_time=1201666921
Here is the "original" thread, I eventually gave up and sold it after being confident it was fixed all those times: http://www.bikeland.org/board/viewthread.php?FID=27&TID=26799
posted March 12, 2008 11:06 AM
mine does not use a drop, i've never seen one that did
you had 2 zx-14's and then you discovered this site with your issue?hmmmmm
as for steve he changes bikes like most change clothes
kaw now
posted March 12, 2008 11:11 AM
My 06 oil level never seems to go down at all and I beat it the same as anyone would. Change the oil about every 2000 miles with Actevo. The best motorcycle oil and change interval is still raging after I was absent from the scene for about 17 years - somethings never change. Mine even seeps out of the valve cover. I checked that after seeing the threads on here. No engine knock either. Did I miss any other common problems? Oh yeah my gas tank has that characteristic dent on the left side. Also while I'm at it tell the Hayabusa guys its a 13.5 just like the 1052cc ZX11 was a 10.5. And there is no storage under my seat either. I wouldn't want any other bike.
posted March 12, 2008 11:27 AM
quote: still raging after I was absent from the scene for about 17 years - somethings never change. Mine even seeps out of the valve cover.
oil is seeping out of yours too? I've owned serveral bikes in the last 17 years. Kawi's included. My 14 was the only one leaking oil
posted March 12, 2008 11:32 AM
the only leakers i had were hondas
BobC
posted March 12, 2008 11:46 AM
Edited By: BobC on 12 Mar 2008 12:51
I agree, a quart in 1000 miles is not acceptable. My bike has not needed any oil between oil changes. Since the break-in period it's been running on Rock Oil 5W 30 full synthetic, It's done maybe a hundred top speed runs and a couple of dozen runs on the dyno as well as road riding. The level has not dropped at all. It could be a leak.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
zx12mark
posted March 12, 2008 11:55 AM
thats not right.it's total kawi bullshit.my 2000 zx12r has 43,000 miles and i change the mobil 1 20/50 every 2000 miles and it is still in the middle of the site glass when i change it. .i never have to add oil .3 quarts exactly goes in with a new filter each time.
kaw now
posted March 12, 2008 12:18 PM
quote: oil is seeping out of yours too? I've owned serveral bikes in the last 17 years. Kawi's included. My 14 was the only one leaking oil
I've read plenty of threads of the 06-07s that seep oil from the valve cover, I wouldn't classify a seep as a leak as no dripping on the floor or noticeable oil loss. However it is coming from the valve cover I understand shimming up the bolt head or new bolts solves the problem but its so minor I'll get to it at some point when the fairings are off. I agree its a little uncharacteristic of Japanese bikes to have any engine that seeps or leaks oil at all.
lietoome
posted March 12, 2008 12:19 PM
my zx12 had a leaking valve cover gasket w/1500 miles. I've put 10K miles on the 14 and no issues. If you're losing that much oil, you've got an issue---its just not normal. I'd go back to the dealer and have that kawi-tech put that in writting. i call BS!
just curiuos, but what weight oil do you use.
FasterThanStink
posted March 12, 2008 03:08 PM
You have obviously never owned an Italian bike. :P
That's what gets you.
