BIKELAND > FORUMS > ZX-14.com > Thread: 15mm risers NEW TOPIC NEW POLL POST REPLY
NinjaNick
'08 ZX14 (Blue)
posted March 11, 2008 02:47 PM
15mm risers
So, I found these risers. Not brand name Heli-bars, but risers. What do you all think about these http://projektd.com/product_info.php?cPath=26_30_33&products_id=33 ?
Would 15mm make much of a difference? Is there any negative side effects from installing these?
Thanks for any advice.
jeff martin
Pro (closed)
jamming
posted March 11, 2008 02:59 PM
The heli-bars also set back..I think 3/8 inch and there only $64.00 And machined out of solid stock..And people i have spoke to depending on how tall you are..Says it makes a big differnce..
i play with boats my wife plays with my dingy.
  Ignore this member    Click here to visit jeff martin's homepage.
NinjaNick
'08 ZX14 (Blue)
posted March 11, 2008 03:11 PM
I'm going to look around and see if I can find some heli-bars for an '08.
FasterThanStink
posted March 11, 2008 04:35 PM        Edited By: FasterThanStink on 11 Mar 2008 17:36
The Heli Risers are good. They have the max amount of lift you can get without the brake fluid container running into the windshield. As for the offset, well that is just a function of the rake angle of the forks. Any raising of the bars is naturally going to supply a small amount of rearward offset. The 15mm risers would also have offset to the rear. The risers fit all 14's so you do not need to worry about the model year.
http://www.helibars.com/products.php?cat=11
That's what gets you.
NinjaNick
'08 ZX14 (Blue)
posted March 11, 2008 04:47 PM
I wonder if it's much improvement being only 3/4" total. The zx10 and others are doing 2"-2 1/4" taller. :
FASTESTbusaAROUND
I eat Fish...
posted March 11, 2008 05:24 PM
Makes HUGE difference for me. I use the Helibar's myself -- cheap and well built. I'm 6'2" @220
FYYFF!!!
FasterThanStink
posted March 11, 2008 06:39 PM
It's a huge difference. 2 1/2" risers on a 14 would be hitting the windshield. Small changes in geometry have big effects on comfort and handling.
0.21152305603027 seconds processing time
