BIKELAND > FORUMS > ZX-14.com > Thread: Bazzaz - anyone here use it? NEW TOPIC NEW POLL POST REPLY
posted February 24, 2008 09:52 AM        Edited By: dubious on 24 Feb 2008 09:52
Thinking of getting rid of the PC3, hub and LCD.
Anyone here know anyone, who uses Bazzaz system on any other bikes?
Looking for feedback on their system.
posted February 24, 2008 10:15 AM
Checked it out with google, if you had the air fuel sensor it could be self tuning? Interesting system. I will read more, but I have not seen one in use, it says available in February, so you are on the front end of this thing, the software looks cool.
kawabunga
Cogswell Cogs Installed
posted February 24, 2008 10:27 AM
Very expensive piece and limited as well on options unless you add the fuel mapping option. You'll be in the 800 - 900 range and the real expensive way to is with the traction control box plus the fuel mapping $$$$$$$$$$$...the less expensive route works about the same as a Yosh box and you can probably pick one of those up used pretty cheap.
ZXLNT
posted February 24, 2008 11:35 AM
They make a Yoshimura box for the ZX14???
posted February 24, 2008 01:41 PM        Edited By: dubious on 24 Feb 2008 13:43
Well, they have a self tuning A/F feature when u use the appropriate equipment, and the price is approx. $650 with the ZFI, also allows quick shifter. The traction control is another $300. Not so interested in that might become interested once the turbo is on the bike...LOL
For $650 you get a piggyback ecm, 2 map switchability, quick shifter ability, self tuning A/f for "your" desired ratio, trim adjustments in each cylinder, and ignition timing control as well!
Also it is great for nitrous and turbo as it will drive up to eight injectors, so its good for piggback fuel systems, and the ignition timing can be altered due to boost, throttle, and gear position!
Basically the perfect addtion and stand alone for a progressive boost controller!
No more heaps of equipment and spaghetti wiring under the hood!
If you add up the PC3, wideband commander, hub, and ignition module,
the price actually is very competitve, and better than the DJ setup with dual PC3's necessary for piggy back fuel systems on high HP turbo applications.
The features are awesome, I can only dream it would adjust the fuel map for a boosted bike too....
Will have to find out!
What i meant to ask is how user friendly is it, how is the sampling and datalogging.
Questions I will beasking when i call them tomorrow.
lietoome
posted February 24, 2008 03:05 PM
MSD is suppossed to have their setup available in May. I'd shoot them an e-mail before I bought anything. From what I'm told, it will do everything you need for around $500.
kimski2001
posted February 24, 2008 05:31 PM
dubious,can i have 1st dibs on the lcd and hub?
1st14injax
posted February 25, 2008 06:10 AM
a friend is already interested.... sorry
posted February 25, 2008 02:59 PM
will look into it.
Contray to my initial impression, if you want to upgrade you have to buy a new unit with the new features... except the AFM module
http://www.bazzazperformance.com/index.php?page=shop.browse&category_id=3&option=com_virtuemart&Itemid=26&vmcchk=1&Itemid=26
I called them today.
very nice ppl, and helpful.
0.48942112922668 seconds processing time
