BIKELAND > FORUMS > ZX-14.com > Thread: Perfect Map for Brock Pipe and my setup NEW TOPIC NEW POLL POST REPLY
Superman T
posted February 21, 2008 12:22 PM
OK, I still have my Blue 06 completely stock. I bought PCIII & S-meg(that I had sent out to be ceramic coated black Semi-gloss). Brock's technical support has emailed multiple maps but I just can't decide which map would be the best fit. I have BMC race filter to install and changing my oil filter/oil to royal purple. I've heard that the Maxxon map is supposed to be a real good one. Thanks in advance for the great information, I will post pics upon completion. Best Regards
Superman T
posted February 21, 2008 12:26 PM
Oh and one more question. I bought the noise reducer to put in when I'm riding my girl. How does that decel pops sound plugged and any negative consequence to the engine? Anyone experience that?
BlackMagic14
posted February 21, 2008 01:38 PM
I would email Brock and ask him what map he recommends tell him what kind of riding you do and what kind of fuel you will be using. All of the track maps are tuned for race gas BTW if that makes a difference. If you are not drag racing and are running pump gas then go with one of the street maps. I used the maxton map, even when running on the street with pump gas and it felt like it pulled hard with no flat spots
Superman T
posted February 21, 2008 02:06 PM
Cool thanks, I was leaning towards the maxxon map
posted February 21, 2008 02:38 PM
my favorite so far is the maxton map, the bike is smokin fast with it
lucky14
posted February 21, 2008 02:45 PM
OK, I still have my Blue 06 completely stock................
Flies still in?
Unless it was my DJ hub , not switching ... which I would not doubt, I found the maxton map to be terribly rich....
ninja12
posted February 21, 2008 02:58 PM
Open the maps with the software, the notes sections tells what mods the map is for.
I would bet the Street map would be best especially with the quite plug.
It's easy enough to try all the map for your setup to see which you like best.
I like the PC under the seat better than under the ram air cover , because its much easier to make changes.
sideways
posted February 21, 2008 03:31 PM
I sure Brock sent you all the maps. I have used a couple of them. I started out with the maxton map, very rich, better for drag or mile. I would use the smeg/w baffle street map...for the street! Don't get confused with the smeg no baffle maps!
Joe
2006 Blue ZX-14
sideways
posted February 21, 2008 03:34 PM
...also that is provided you have the secondary throttle plates out!
Joe
2006 Blue ZX-14
kimski2001
posted February 21, 2008 05:19 PM
i've tried three of the maps.street map made 187.8hp on pump gas,rode good on the street saved gas,thats it period!performed like crap!(as far as racing was concerned).tried the track map next,made less hp but runs like a raped ape!gas milage not as good,but who cares if you're looking for performance.tried the maxton map on three different occasions,hated it all three times!bike acted really funny,looked @ the difference of the maps and all i can see is the maxton has a little more fuel added in the higher rpm's.my choice would be the track map,just depends on what you're looking for.
1st14injax
Superman T
posted February 22, 2008 10:21 AM
Thanks for the responces! I have all of the maps from Brocks and I think I will start out trying the Maxton map and will load a different one if I'm not happy with it. I can't wait until I return to perform my mods!
posted February 22, 2008 01:03 PM
I agree with this statement completely!
I had the same opinions.
1badzx12r
posted February 22, 2008 01:04 PM        Edited By: 1badzx12r on 22 Feb 2008 13:05
+2.... on idle some of the brocks maps are super rich
posted February 24, 2008 06:11 AM
it is only richer than the track map at wot and not that much, my bike likes it in this thick florida air
Rob Frink
posted February 24, 2008 10:26 PM
I agree with Dubious and Kimski I tried all three (3) as well an for street riding seemed to noticed bike was getting was too much fuel for stop and go riding which depending upon where you live you are going to do. The Maxton map seemed to be alright for WOT but on the street how many times would you get to do that. My .02 the track map was alot better for riding around town
Superman T
posted February 25, 2008 10:49 AM
My bike is located in Sanford, Florida and a few of the guys on this forum are also located in FL. I wish I had a LCD for the Power Commander, then I could oscilate and pick the best for my bike. But dealing with reality I must choose one. Does it really matter where you located to compensate for the map choice? Right now I'm leaning towards the Maxton map but I start to sway as I read these threads. I would like to pick the right one.
Superman T
posted February 25, 2008 11:11 AM
Let me add that I will be mostly riding locally and will crack the throttle under controled circumstances. Occasionally I will take it on long trip.When I take it to the track, I will change for that
posted February 25, 2008 02:28 PM        Edited By: bigdtd on 25 Feb 2008 14:29
went out sunday and butt dynoed all three maps, the street map is the tamest and gets best mileage, the track map is an improvement over the street but to me the maxton has the most punch, go with the track or the maxton, you will love it. if mileage is a concern the street is best. who gives a crap about mileage on a 14???
all this testing in pinellas county, fla
0.23393487930298 seconds processing time
