BIKELAND > FORUMS > ZX-14.com > Thread: The Wheel Lock NEW TOPIC NEW POLL POST REPLY
redsnake2
posted February 19, 2008 05:08 AM
The Wheel Lock
Ok on my bike in order to pull the key out you have to have to wheel locked all the way to the left.. Well im about to trailer my bike to Myrtle and this will be a problem putting it in the wheel chokes..
Is there a position on the ignition where I can keep the wheel striaght and pull out the key??
Sigma14
posted February 19, 2008 07:54 AM        Edited By: Sigma14 on 19 Feb 2008 07:54
I don't have to put mine in lock position to remove key. It should come out in off position. If not you may try parik position. You can only lock wheel in that position.
obba
posted February 19, 2008 10:23 AM
If you need a quick fix.
Buy one of wheel disc blocky lumps that lock through the wheels.
High visability fluro pink or yellow (put on rear wheel so easily seen by people),
Get the model with a built in high pitched siren that activates when movement is detected.
So you don't drive off with it still in place - OWWW!!!! (Even with the Fluro colours it has happened).
Tool Man
posted February 19, 2008 12:27 PM
Key will come out in the "OFF" position and that will allow the wheel to be straight.
I do it all the time
...if not it's broke.
The banks are failing..
The banks are failing...
Invest in Ammo
0.34448909759521 seconds processing time
