BIKELAND > FORUMS > ZX-14.com > Thread: TRE-006a NEW TOPIC NEW POLL POST REPLY
cagey
posted February 03, 2008 10:45 AM
TRE-006a
I plan on getting a brocks alien head(and PC) for my 06 zx14. Will I need to get TRE-006A to get rid of the pop. I guess there is two questions here 1. will I defiantly get the pop sound with that set up? and if so will the TRE006a fix that?
posted February 03, 2008 11:18 AM
there is a plethora of TRE info posted already, plus "decel pop"search if you do a search by clicking the top left search link.
The TRE won't fix the decel pop-
cagey
posted February 03, 2008 11:27 AM
yeah the search function of this site sucks....how bout answering my question.
posted February 03, 2008 12:39 PM
huh???
I did answer your question, right in my above post....
here it is again for you in bold: "The TRE won't fix the decel pop-"
posted February 03, 2008 12:40 PM
and since there IS a decel pop in my answer, in case you didn't figure it out you question number one the answer is yes, there will be a decel pop.
warbird
posted February 03, 2008 01:02 PM
I'd Rather Be Roadracing.
posted February 03, 2008 01:08 PM
man, try to suggest a search and even give an answer and they still kick me in the nutters lmao
granpa
posted February 03, 2008 01:16 PM
Yes the tre006a will make the decel pop go away but it is only to be used with the flys removed. I have Brocks smeg and mine doesn't pop at all. Also have 2 riding buddies with the tre006a and they have no pop either.
kawabunga
Cogswell Cogs Installed
posted February 03, 2008 01:26 PM        Edited By: kawabunga on 3 Feb 2008 13:28
Map the PC correctly for flies out....forget the TRE, it's junk !!! If your Alien Head doesn't come with the red plug used to plug the hose coming from the Kleen air system to the bottom right side of the air box find something to plug the hose off totally going to the air box. This virtually eliminates the popping on decel.
2002 zx12
2002 zx12
posted February 03, 2008 02:46 PM
There is two different TRE one for the poping with the flies out and one to give you the bottom end with the flies in and just pluging off the the air box does not take care of the poping sound I have Gen3 exhaust with the air box plug in and have the block off plates and mine stills pops Know five other people with different full systems and theirs pops also.
posted February 03, 2008 02:52 PM
yes, the pop will be there. significantly reduced with the plug and correct map, but you will still get at least one big bang on decel.
I still am amused by cagey's rudeness above
FASTESTbusaAROUND
I eat Fish...
posted February 03, 2008 06:46 PM
Steve -- yes he is very rude and obviously blind too, but the 006A DOES get rid of the pop from what I've heard. That's all it's designed for, from my understanding, but then, so does a 270 Ohm resistor on the same wire.:d
FYYFF!!!
posted February 04, 2008 07:53 AM        Edited By: fish_antlers on 4 Feb 2008 07:53
bullshit!
Type "TRE" into the little white box on the top right corner of your screen that says "search" ... works just fine ...
It's the Internet... try it sometime!
Sticks_n_Stones
posted February 04, 2008 10:28 AM
heh heh heh... never know where Fish is gonna turn up!
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
fastestbusaaround
I eat Fish...
posted February 04, 2008 11:08 AM
Some people - go figger eh? Rude little cocksucker he was too...
FYYFF!!!
cagey
posted February 07, 2008 08:15 PM
i didnt realize this site was full of a bunch of sensitive bitches.......go fuck your self steve. now thats being rude.you fucking little girl.
posted February 07, 2008 08:20 PM        Edited By: stevewfl on 7 Feb 2008 20:21
dayum who is sensitive, bish???
FASTESTbusaAROUND
I eat Fish...
posted February 07, 2008 09:18 PM        Edited By: FASTESTbusaAROUND on 7 Feb 2008 21:21
What a jackoff -- his name suits him well --
Steve -- yer a moderator and called you a bad name; he ain't got no ree-spect. He needs to learn a lesson...needs a good spankin'
FYYFF!!!
BlackMagic14
posted February 07, 2008 09:47 PM
LMAO I like him I would let him be my bitch LOL
lucky14
posted February 08, 2008 09:13 AM
Brock is now selling Ivan's TRE on his site.
I guess that the TRE-huggers are now vindicated!!
Quoted from Brock's site:
SKU: IVAN-TRE-006A
TIMING RETARD ELIMINATOR ZX-14 06-08 Requires sub-throttle plate removal & special mapping. Gets rid of fuel shut-off on decel-This will allow smooth on/off throttle transitions and will get rid of the annoying pop when the throttle is reapplied.
Sticks_n_Stones
posted February 08, 2008 11:41 AM
Hahahahaha now THATS gonna throw the fellas in a tizzy! Starting with Steve! Hows that crow taste?
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
johns
posted February 08, 2008 06:23 PM
To give you a straight answer Cagey, yes the TRE-006 works as advertised. It eliminated the decel pop on my Brock piped ZX-14 and on several friends bikes. DO NOT install it on a ZX-14 unless you have removed the flys. It will slow down a bike with the flys installed. You will lose you're gear indicator (reads N all the time) and the neutral light still works. Go to Brocks site for an independent test result on this product. Brock also indicates there may be a slight loss at the drag strip using the TRE-006.
2006 ZX-14 (sold)
2012 ZX-14R (Brock's Perf. project bike Louisville Slugger)
2013 Honda VFR1200F
2003 124 C.I. H.D. Super glide
cagey
posted February 08, 2008 06:59 PM
Thank you Johns and all others that helped me with my inquiry. you see steve there are people, not unlike myself that come to sites like these in search of a quick answers to our zx14 questions. sure, i could stumble around the net (fish) looking ,but thats why sites like this were created...............
BlackMagic14
posted February 08, 2008 07:08 PM
I think the point was to not have 500 duplicate threads with the same content AND YOU WERE RUDE!!!
cagey
posted February 08, 2008 07:10 PM
well if you read this thread you will not find this info on any other thread.the reason i know this is i read them all.
0.22517991065979 seconds processing time
