BIKELAND > FORUMS > ZX-14.com > Thread: Turbo install ..JesseJames zx14 NEW TOPIC NEW POLL POST REPLY
smokinzx14
posted February 01, 2008 10:11 AM        Edited By: smokinzx14 on 1 Feb 2008 10:29
Ok guys here we go ....Here is a picture of the kit and parts..
Next shot is a picture of the turbo its self ..
Other side of the turbo..
Turbo hung on motor.
Up pipe , charge tube.
Block off plate and nipple for boost gauge .
In order to install the header and turbo you will need to remove a small nub on the front of the engine .. This nub doesn't hold anything or have anything bolted to it ...What it is there for i have no clue ...I removed it with a die grinder and only took a few seconds to remove ...The turbo fits well after the nub is removed ...I had to rotate the turbo housing just a few Degs to get the up pipe to fit just right ...It would have been ok without this little adjustment but it fit just a bit better by doing so .. Well that is it for now , more pictures and text as i get a little more done .. Smokin..
smokinzx14
posted February 01, 2008 10:18 AM
This is Jesses bike so don't tell me i need to wash my bike !!!!! But you can PM Jesse and tell him to wash his bike ...lol....
brent davis
posted February 01, 2008 11:27 AM
Hot damn is that looking good. Thanks Smokin' for the updates. Looking forward to the track and dyno results too.
Black '06 ZX-14
kawasaki_rick
posted February 01, 2008 11:56 AM
i think the turbo should blow the dust off it.
posted February 01, 2008 12:12 PM
wow this is great stuff- keep this thread posted with pics
1badvespa1400cc
power junkie
posted February 01, 2008 01:15 PM
Yeah,keep up the detailed photos any help is appreciated!!!!
Just another foeteen!!!!!
KINGTRAMP
posted February 01, 2008 01:31 PM
Thanks very much for sharing your project, it got me strongly reconsidering NOx use.
SteddyTeddy
posted February 01, 2008 04:08 PM
Damn that thing looks like it will be ready for a dyno run tomorrow.
smokinzx14
posted February 01, 2008 04:35 PM
Picture of the Fuel Reg and bracket.
Picture of the turbo oil evac pump and bracket.
1badvespa1400cc
power junkie
posted February 01, 2008 05:45 PM
Sweet keep those pics goin!!!!!!!!!
ninja12
posted February 03, 2008 06:30 AM
Smokin, you don't have to sleep every night?
Come on we need updates.
SteddyTeddy
posted February 03, 2008 06:43 AM
I stopped over yesterday and we got the lowered oil pan installed, oil feed line and radiator positioned and mounted. No install instructions were sent with the kit and they were suppose to show up yesterday but didn't. All the hoses and lines are precut and smokin needs to see how the guy planned to mount and run everything. It will be a couple days yet until it's running.
smokinzx14
posted February 03, 2008 05:17 PM        Edited By: smokinzx14 on 3 Feb 2008 17:23
Here are a few my pictures for you guys with the rad fitted ..
We did have to modify the lower Rad support bracket a bit ..It had the be shimed 1/4 inch away from the block and we also had to grind it to clear one of the turbo flange bolts...You can see what we did in the first picture . You can also see where i had to grind that nub off the block to clear the turbo flang , it's just below the lower Rad support bracket ..Smokin..
Brent Davis
posted February 03, 2008 07:32 PM
overall Smokin', how do you rate the kit so far? I was told that it is a bolt on and go.....Hmmmm seems like you are doing some mods to me. I am sure it will perform well but a bolt on is bolt on without shimming and cutting off engine tabs.
Black '06 ZX-14
KINGTRAMP
posted February 03, 2008 07:37 PM
Smokin who makes the kit, cost, & a point of contact, if you could please. Thank You very much. And best of luck with kit. Plan on going to BMSP 10 feb ?
smokinzx14
posted February 03, 2008 08:23 PM
Well i hate to give a report till i see how it runs.....So far i don't feel too bad about it and at this point i would say it's 8 1/2 out of 10 so far but that could change .. . I have done a few turbo kits over the years and i have not had one that didn't need some mods of some kind ... I don't know if anyone really makes a true bolt on turbo kit ...
The CNC parts are top notch , the tig welding on the header looks to be very good, the welding on the charge tube is a little ugly and the charge tube itself looks like it could have been done a little better ..
The Tec help from Dave has been very good, but we did have to wait to get the kit ( 4 weeks ) ..Part of the wait was do to changes we made to the kit from the stage one kit that he builds..
The two little mods i have made where very easy to do , but i'm not done yet with the install so there maybe a few more before it's all said and done ...
Smokin..
smokinzx14
posted February 03, 2008 08:26 PM
The Kit is made by CycleLogic Motorsports .. http://www.cycle-logicmotorsports.com/ The prices are on there website ... What's going on at BMP on Feb 10th ?
smokinzx14
posted February 03, 2008 08:38 PM
I have a deal for anyone in FL ... If you buy a Muzzy Turbo Kit i will do the install at half price .. I really want to compare kits and i would do the same write up and pictures as I am doing for the CycleLogic Motorsports Kit ... Only catch is i get to make a 1/4 pass on it ... I'm kidding about the last part ...I really would like to find out whos kit is the best so bikeland members could get the best bang for there buck.. ...Smokin..
posted February 03, 2008 08:49 PM
If you buy a Muzzy Turbo Kit i will do the install at half price .. .. ...Smokin..
wow what an offer, bet you are busy soon!
nightmare
ACP Racing
posted February 04, 2008 11:42 AM
what kind of horses are you expecting lee and has anything been done to the motor as of right now? I am asking because you are very limited to the amount of horse power you can throw down before you have to worry about spinning a bearing. was there an upgrade on the pistons as well. I talked to Cesil and bob and they let me know that the rids in the 14 could stand almost 300hp so no worried there right!
2006 ZX14 Ninja "SWINE FLU"
60ft 1.23
8th Mile 5.16
ACP Racing
smokinzx14
posted February 04, 2008 01:40 PM
We are running low boost ( 8.5 ) and that should be good for 260 HP and safe on the stock motor with pump gas ...We are not going to use pump gas, to be safe we are using c16 .... About the bearings , only one guy has had bearing problems with a turbo and trust me the bearings were not the problem ..Muzzy said the stock parts are good for 280+ HP .... After we max out what we can run at 8.5 boost we will add a set of rods and pistons If needed ....I believe that we can run up to 12 PSI boost with a good mapping and c16 fuel on the stock parts with no problems ...The four weak links in any stock motor are the pistons and rod bolts ...The rod is plenty strong but the bolts are not ..The pistons are weak in the valve pocket , the valve pocket is cut way to close the the upper ring land ...3rd is the oil , we have added new pan with an extra QT of oil ..We also upped the weight from the 10w30 to 15w50 ... Last but not least is the mapping ... it will be mapped at around 11.2 A/F at full boost , at that fuel ratio the fuel becomes a coolant ...Cooling the intake charge is a must to make even an after market piston last in a turbo motor .. The trick is to tune out any chance of spark knock .. Spark knock will kill a rod bearing or a piston less than a second ....
KINGTRAMP
posted February 04, 2008 03:48 PM
If I am not misaken, BMSP is having a Runday Sunday.
zx14bert
posted February 04, 2008 04:10 PM
Hey smoke.what oil pan are you using?The muzzys kit fits very nice,problems i am having is nothing to do with the kit.
smokinzx14
posted February 04, 2008 04:51 PM
The pan is a Coby Adams modded stock pan ...
posted February 04, 2008 06:07 PM
thats it i'm bringin mine over , let me see what kind of deal i can get on the muzzy.......
All times are America/Va [ This thread is 10 pages long: 1  2  3  4  5  6  7  8  9  -  10   Next» ] < Previous Thread     Next Thread >
0.22740292549133 seconds processing time
