BIKELAND > FORUMS > ZX-14.com > Thread: Drag Racing Gearing 16/41 or 17/44 NEW TOPIC NEW POLL POST REPLY
spyder636
posted January 13, 2008 11:02 PM
I weigh about 200 pounds fully suited and was wondering what the best gearing for me is going to be. The bike will be stretched out about 6". Thanks guys
06 ZX14
Flies out
PCIII
Brocks Exhaust
Lowered and Strapped
Stretched and Geared (SOON)
jarhead
posted January 14, 2008 01:43 AM
I ran -1 in front and +2 in the rear when I ran on motor. That was at 65" wb, I am about 10 lbs lighter but I think we would be pretty close. Great looking bike, mine is red as well, I am in the middle of putting together a bike race in Muncie, Indiana. They have a freshly paved track now. Hope to see you there.
kawpower
Mr kawasaki 2 you!
posted January 14, 2008 05:45 AM
16/43
spyder636
posted January 14, 2008 09:21 AM
Ill be there forsure jarhead.
zx14mike
posted January 14, 2008 02:58 PM
I would go with 16/42, i think its perfect for both the street and the drag strip.
spyder636
posted January 14, 2008 08:19 PM
Is 16/42 that much different from going up to a 44 in the back and leaving the front sproket alone??
06 ZX14
Flies out
PCIII
Brocks Exhaust
ninjaboy311
posted January 14, 2008 08:30 PM
16-43
zx14mike
posted January 14, 2008 10:46 PM
16/42 is a little more gearing than 17/44 and should give a little more acceleration and snap but they are pretty close the ratios are 2.62 vs 2.59..............also you can run the 1642 with a stock chain, while you will need to replace the chain to run 17/44.
zx14mike
posted January 14, 2008 10:48 PM
Actually 16/42 is closer to 17/45 than 17/44.
lietoome
posted January 15, 2008 01:38 AM
I run a 17/45, then swap the 18t when I go on road trips.
Silver08
posted January 15, 2008 09:18 PM
16/43 here,
08 ZX14
02zx12rbob
posted January 16, 2008 07:08 AM
15/44.
00Busa
Trying to go FASTER !
posted January 16, 2008 07:49 AM        Edited By: 00Busa on 16 Jan 2008 07:50
Man you guys are running some serious gearing. I ran 16/42 until the last race usually low 5.80s @ high 123 mph but kept hitting the rev-limiter going through the traps. I changed it to 16/41 and went my 5.79 (twice) and finally 5.77 @124.66 at around 10600 rpm. I'll find out when Commerce opens how it's doing in the 1/4th.
'00 Busa / '06 14 /
IT AINT BRAGGING, IF YOU CAN BACK IT UP !
lietoome
posted January 16, 2008 09:05 AM
I'm a big fella, need all the gear I can get. Hell, I'd rin a 1 tooth on the front if it helped.
0.26774311065674 seconds processing time
