BIKELAND > FORUMS > ZX-14.com > Thread: your experience with the 14 NEW TOPIC NEW POLL POST REPLY
starchild
posted January 08, 2008 07:13 PM
most of you have nearly two years under your belt with the 14, i have a 06 no miles on it was set up to race with a trac dynamics swingarm muzzy air shifter no map to speak of flies in this is what i've done since flies out shift light lock up (mtc) tre 006 will tune in march any input and ideas would be appreciated thank guys
jay
posted January 08, 2008 07:35 PM
Good baseline set up,
dump the flies, GOOD pipe of choice, Brocks and Tiforce are the stronger ones,
map, gears , shinko u3 soft, strap frt end, proper spring for extended wheelbase...
Run it hard!
posted January 08, 2008 07:38 PM
oh, and strip as many useless pounds of pork as you can....
if your not using it on the street remove everything you possibly can...
I love my 14, but damn they are heavy pigs.
starchild
posted January 08, 2008 07:45 PM
thanks dubious will take your advice
jay
Nelson Taylor
posted January 08, 2008 07:51 PM
x2
dubious gave you great info.
they are great bikes and made for drag racing.
Lower your center of gravity as much as you can
The Catalyst Drag Seat feels good when your sitting in it.
It gets you low and supports you in back.
Best #'s
1.54
4.03
6.02 @ 121mph
(Stock Wheelbase) 2006 ZX14
starchild
posted January 08, 2008 07:56 PM
i forgot to mention i have the drag seat from catylast also
jay
BlackMagic14
posted January 08, 2008 09:41 PM
You dont need a lock up with a stock motor 14 put that money elsewhere...
busajack5
Rocket lll
posted January 09, 2008 11:57 AM
Hey DUB,speaking of weight,do the 06&07s have as much foam under each tupperware panel? I dont remember the busa having all that much.Yes its only foam but it must add up. Also do you guys know if it absorbs water when you wash it or is it a closed cell type of foam.Is the bike that noisey that they had to use that much foam for the EPA.Also whats the deal with that punney air filter.Its small enough but then they add that alum. plate (which I took off) to it.The busas surface area for the air filter must be 4 times as big.Not complaining just interested in Kaws theorys and trying to learn..Jack
Jack
BlackMagic14
posted January 09, 2008 02:02 PM
The foam PLAYS A HUGE ROLE in reducing the amount of heat you feel on your legs!! I think the best and easiest way to shave weight if you are keeping it on the track areget rid of the rear seat cowl, the small fairing under the swingarm, the rear passenger pegs, switch to a smaller ZX10 front fender, toss one of the front brake rotors and caliper, get some lightweight levers and rearsets. And if you got all kinds of money start adding Carbon fiber: wheels, stator and clutch covers. Also I was talking to a guy the other day that went with all composite hoses on the radiator and the other hoses he said total that shaved about 3 pounds and only cost about 30 bucks total. Not to mention when you get rid of the stock exhaust you will shave about 40 pounds!! of course if you want to take it farhter I think Catalyst bodywork shaves some pounds if you do all the plastics and probably 15-20 if you go with a composite tank!! but the tanks are 800 I think>>>
0.21054100990295 seconds processing time
