BIKELAND > FORUMS > ZX-14.com > Thread: Shinko or Power Pilot 2CT NEW TOPIC NEW POLL POST REPLY
spyder636
posted January 07, 2008 09:57 PM
I have heard great things about both tires. This tire will mainly be used for drag racing?? Also would you recommend a 190 or 200???
Silver08
posted January 07, 2008 10:00 PM
power RACE soft, you dont need the 2CT for drag. and 190
i am about to try one of these. a lot of use have used shinko Usofts successfully.
08 ZX14
lietoome
posted January 07, 2008 11:51 PM
I would only use the Shinko U-Soft for dragracing. Sure you can use it on the street, but the profile of the tire is rather wide thru the center which means less contact when leaned. I took an emergency 500 mile trip on my U-soft, I had to mount new rubber before my return home. It was almost to the wear-bar and I didn't want to risk another 500 miles @ 90mph+. With that said, I had a total of 1800 road miles & probablly 30 passes on the 1/4 with the u-soft before I changed it out.
Aren't the 2CTs rather expensive? I don't know anything about them. I do love my pilotpowers though.
Bently
2012 14r In Blue and no Mods!
posted January 08, 2008 03:03 AM
if your not stretched the power 2ct will be fine. But the regular pilot power would work just as good. that's what I ran on mine until I went to 62 inches then I went with the shinko.
00Busa
Trying to go FASTER !
posted January 08, 2008 04:56 AM
I have the regular Pilot Power on my SWB Busa and I like it a lot. I've run Shinkos 200 and 190 on it in the past but the Pilot hooks better and is lighter. I have a 190 U-soft on the '06 14 but it's about 4" over. I'm going to put a Michelin on it when it wears out and see the difference.
'00 Busa / '06 14 /
IT AINT BRAGGING, IF YOU CAN BACK IT UP !
serius blk
posted January 08, 2008 06:45 AM
so let me get this straight. do the u soft say it on the side of the tire. Mine has 003rr but no u soft on it. Im trying to see if i got the wrong one.
00Busa
posted January 08, 2008 08:00 AM
Yes it has U-soft written on one side of it but it also has 003RR on it.
'00 Busa / '06 14 /
blue max
posted January 08, 2008 10:14 AM
i did the same thing last year, i didn't get the u-soft, they say the r003 will work and mine did at times. every time i tried to get my 60's faster i would spin or sometimes it would hook, unpredictable, my bike is at 64". i will get the u-soft this spring. i will need a front tire also, any ideas on that?
best 9.23
spyder636
posted January 08, 2008 10:45 AM
My bike will be about 5 inches stretched out and I am not really worried about big lean angles. I just want a tire that is gonna hook and give me the best ET's.
06 ZX14
Flies out
PCIII
Brocks Exhaust
Lowered and Strapped
Stretched and Geared (SOON)
tater
Shakin off the Haters
posted January 08, 2008 11:56 AM
well what would be a good tire for the street?
ZX-14 06
Flies out
-1 front, +2 rear
2 Bros carbon fiber pipes
Tiger tail
Carbon fiber windscreen
64inch wheel base
lowering links
RC components wheels
BlackMagic14
posted January 08, 2008 12:45 PM
Good ole regular Pilot Power are great for the street!!
00Busa
posted January 08, 2008 01:08 PM
I agree 100% !
'00 Busa / '06 14 /
serius blk
posted January 08, 2008 01:47 PM
i dont know now. Ive been through pilot power, battlax, shinko 003, macxis, and the micky thompson street/ race tire. The only on that would grap was the battlax. Mind the bike wasnt x tend either. I guess ill try the u soft since apparently i bought the wrong one. Im looking for a serious street tire that you can strip with also. Or am i hoping for to much on the street. I just want the bike to grip so i can see what it will actually do. Yes i know at the strip it will grip with the sticky stuff. Since ive extend it i havent found a tire to grip.
00Busa
posted January 08, 2008 02:03 PM        Edited By: 00Busa on 8 Jan 2008 14:05
I ran 8.80s at Rockingham back in November on a Stock wheelbase Busa with 24 lbs and a Pilot Power. I got low 1.50 60ft every pass and never spun once out of 11 passes. Suspension set up has a lot to do woth it as well as a good "hooking " tire. I ride it on the street with 32~35 lbs, still not spinning.
'00 Busa / '06 14 /
serius blk
posted January 08, 2008 02:06 PM
The mickey thompson would grip well when it was stock wheelbase. Only problem i had with it was it would hold air for some reason. I lowered the psi to 18 and ran it hard. The next thing i notice was it keep going flat. No nail or anything in it.
00Busa
posted January 08, 2008 02:07 PM        Edited By: 00Busa on 8 Jan 2008 14:09
I tried a shootout tire once and it was TOO MUCH hook for me plus it seemed out of round and did a lot of "bouncing" when doing a burn out.
'00 Busa / '06 14 /
serius blk
posted January 08, 2008 02:09 PM
i thought maybe my coil was to stiff. I loosened it up and set up the shock. The only time the shinko wouldnt spin was with someone on the back.
00Busa
posted January 08, 2008 02:10 PM
Maybe you just got TOO MUCH HP !!!
'00 Busa / '06 14 /
serius blk
posted January 08, 2008 02:14 PM
i dont thing that it. Its a stock 14 with all the regular mods everybody has on here without nitrous or a turbo. I have it a 16/43 gearing and about 6in over. Like you said its most likely my setup. I ll try a u soft this next time and if that doesnt work its for sure the suspension
00Busa
posted January 08, 2008 02:18 PM        Edited By: 00Busa on 8 Jan 2008 14:20
What do you weigh ? I run a U-soft shinko on my 14 but it's only 4" over ( for now ). With 15~18 lbs of air I get consistent low 1.40 60 ft,. I weigh 168~175 lbs . Depending on my gym time. I use a 190 but may try a 180 the next time - 200s are HEAVY !!!
'00 Busa / '06 14 /
serius blk
posted January 08, 2008 02:27 PM
im at 255
00Busa
posted January 08, 2008 02:29 PM
GOOD LAWD !!! And you're spinning ?
'00 Busa / '06 14 /
NinjaNick
'08 ZX14 (Blue)
posted January 08, 2008 02:40 PM
2CT's are made for cornering. If you get PP's, just get the original PP.
Shinko would be better if you're pure drag ofcourse.
serius blk
posted January 08, 2008 02:44 PM
ill try the u soft this next time and will see what happens.
hans
~Love thru motorcycles~
posted January 09, 2008 09:40 PM        Edited By: hans on 9 Jan 2008 21:42
06 ZX14
Flies out
PCIII
Brocks Exhaust
Spyder,
You need to run your bike through a mud puddle to get that "experienced" killer look--
Right now it looks virgin-- But that's not so bad
  Ignore this member    Click here to visit hans's homepage.
0.26227593421936 seconds processing time
