BIKELAND > FORUMS > ZX-14.com > Thread: Krankvent anyone? NEW TOPIC NEW POLL POST REPLY
87gtNOS
posted January 04, 2008 08:56 AM
Krankvent anyone?
Krankvent anyone?
educate me.....
thanks
01 ZX12R
posted January 04, 2008 05:08 PM
What you talkin about bro?
87gtNOS
posted January 04, 2008 05:10 PM
Hey man...google is your friend!! LOL!!
http://www.et-performance.com/kv.html#METRIC_RACERS_&_CRUISERS
01 ZX12R
posted January 04, 2008 05:26 PM        Edited By: dubious on 4 Jan 2008 17:33
Cool,
I need something like that for my ATV.
Went from 7.9 to 11.5 compression, new cams and valve springs, and extended redline from 7000 to 9000 RPM and it blows oil out everywhere.
I just never got around to plumbing a catch tank yet, these look like a better idea.
Appears to prevent crank pressure, and yet knock out the oil vapour!
87gtNOS
posted January 04, 2008 05:28 PM
I read the R1 forums...pertains to my APEX snowmobile. So lots of the R1 guys run this, or a version of it.
01 ZX12R
posted January 04, 2008 05:36 PM
Not sure what you think of it but I just bought a Rhnegade xp800!
Nasty little bitch! Really light!
Not the top end speed of a big 4 stroke but it really hauls the mail off the line till about 90 real world MPH!
87gtNOS
posted January 04, 2008 05:43 PM
I saw you post on dootalk I think...I saw dubious, and thought, "I bet that's dubious with the ZX14!".
01 ZX12R
posted January 04, 2008 05:51 PM
Yup!
lietoome
posted January 04, 2008 06:40 PM
i figured you were talking about the crankcase vent mod on the zx12s.
busajack5
Rocket lll
posted January 05, 2008 01:05 PM
Thats a hardly problem.Even the 08s do it.Been doing it since 1909..I see the price hasn't come down for a fancy PCV valve..
Jack
davisag
posted January 05, 2008 01:26 PM
hi
yes think i know what you are talking about, as i have carried out this mod
removed pipe from crankcase vent to airbox, and pipe from reed valves on valve cover from air box, and connected a pipe direct from the crankcase vent , to a y piece,and to the rocker cover
also removed the solonoid valve , and fitted a resister to fool the ecu into thinking it was still there to prevent going onto a safe mode map
on dyno seems to have shown a 3 hp gain on my tuned engine
art
Cajunboyz
posted January 05, 2008 05:25 PM
hi
art
What kind or size resistor did you use?yho did you hook it up? I was thinking of removing the solenoid also ,But knew that if i disconnected the solenoid it would set a code.
lietoome
posted January 06, 2008 03:12 AM
Art, which bike did you do that mod on?
davisag
posted January 06, 2008 04:49 AM
hi
you need a 20ohn resister. i soldered on two wires to the resister . and then fitted to the orignal feed plug connecter
art
posted January 06, 2008 05:06 AM
hi
art
Art,
I didn't quite get this.
Basically you plugged the air box PCV hole, and routed the crankcase vent to the air injection port for the exhaust?
87gtNOS
posted January 06, 2008 06:52 AM
My solenoid has been in the garbage since August......I got no codes.
01 ZX12R
lietoome
posted January 06, 2008 07:29 AM
davisag, was this mod on a 14?
posted January 06, 2008 07:49 AM
+1!
davisag
posted January 06, 2008 02:08 PM
hi dubious,
yes that is correct, and without the 20 ohm resister the bike ran crap low down,
will try and post a pic tomorrow
87gtNOS
posted January 06, 2008 03:21 PM
Strange how some bikes react differently to removing the smog solenoid!!
01 ZX12R
posted January 06, 2008 05:37 PM
cool thanks,
mine has had a slight stumble at idle, as well as idling around the block at very low throttle positions below 2000 rpm
87gtNOS
posted January 06, 2008 06:46 PM
cool thanks,
Maybe my TRE is hiding that...but I did have the TRE off in September for about 3 weeks.....
01 ZX12R
davisag
posted January 07, 2008 09:36 AM
hi
before i fitted the resister, when the engine was in neutral. revving the engine quickly to around 6.000 revs was producing black smoke out the ex, and dissappeared as soon as the resister was fitted, and that would explain the poor running low down
davisag
posted January 07, 2008 09:54 AM
hi
here is my crank vent pics, turned the right angle bend 180 degrees , on the vent outlet, more room to get the pipe up this side of the engine, and in second pic you can just see red loop of 20 ohm resister wire over the secondary throttle butterfly steeper motor
posted January 07, 2008 12:32 PM
Wow, learn something new everyday.
I will try it out for sure!
Thanks!
0.29845690727234 seconds processing time
