BIKELAND > FORUMS > ZX-14.com > Thread: PC multi function hub-HELP NEW TOPIC NEW POLL POST REPLY
87gtNOS
posted November 14, 2007 12:09 PM
Sorry guys, this is for my snowmobile...same thing though...
I have here my PC, Timing Module and Hub with toggle switch. What I forgot to order was the 'relay harness' wires.
They attach to the 4 prong plug on the Hub.
The Hub's wires are a different color (other than the black) than the wires on the 'relay harness'. i want to chop off the plug and make my own harness.
So anyways, what I need to know is if someone has this setup and knows what wires attach to what wires!!
Thanks eh!
01 ZX12R
posted November 15, 2007 10:03 AM
make sure the power commander has the latest firmware or it will not see the hub. bith dubious and i had to wrestle with getting the firmware on the PClll. the pc site may have a schematic
87gtNOS
posted November 15, 2007 10:10 AM
thanks for the reply bigdtd.
Did you guys have a hard time with the hub when it was on your desk or on the bikes? I haven't put the PC, module + hub on the sled yet.
I was just testing on my desk with my laptop and the 9v battery. The guy I got it from loaded the firmware into the pc and timing modules already. When I click 'about powercommander' it shows the firmware is the latest for both the PC and Module and says no hub hooked up! But again, maybe this is the case on my desk, and won't be a problem once installed....
And crap, the guy didn't put the Ignition Module's programmer adaptor back into the box when he shipped it to me. (this is all new stuff, he just offered to do the firmware stuff as he was doing a bunch of them).
I know on my friend's sled without the hub, we had a hard time getting it to accept the Timing Module!! But eventually it worked!
I will be installing this stuff on the weekend with dyno time booked next Wednesday. I guess if I can't get the hub to work I'll be fine and have to just deal with it the following weekend!!
01 ZX12R
posted November 15, 2007 03:26 PM
hook it all up cycle power and start the snowmobile it all should talk to each other and work. i like the lcd because i get feedback on throttle position and fuel mapping, not to mention the duty cycle percentage of the injectors, my form of bling
87gtNOS
posted November 15, 2007 05:28 PM
Thanks eh!
Here's what I did..... I went and thought I would update the firmware from 2.1.2 to 2.3.0. As I was doing it, my battery died (same 9v I used all summer on the zx14). Stupid me and now I need the 'programmer' to get the PC to work....HOWEVER, the guy I got the PC from forgot to put the programmer back into the box (he had offered to install the firmware before he sent it to me). I have a friend with the programmer I will borrow this weekend.
Meanwhile, the PC wont turn on, but the hub now has a green light...so once I get the firmware in again it should be fine.
PC emailed me, I didn't think they'd help me with cutting the wires for the relay, but he said his suprivisor said it's ok to tell me! So thanks to them!
Thanks again bigdtd for your input!!
I guess this thread is done!!
01 ZX12R
0.3712739944458 seconds processing time
