BIKELAND > FORUMS > ZX-14.com > Thread: Stock wheel base 08 ZX14 goes 5.83 @ 126mph in 1/8th NEW TOPIC NEW POLL POST REPLY
swiftkart
posted November 07, 2007 12:09 PM
Rickey Gadson goes 5.83 in the 1/8 on stock wheel base 08 zx14.
http://psychobike.com/cgi-bin/ikonboard.cgi?s=6570697449708c189bf90c3a9c7e98a3;act=ST;f=1;t=50822
warbird
posted November 07, 2007 12:41 PM
I'd Rather Be Roadracing.
Bently
2012 14r In Blue and no Mods!
posted November 07, 2007 02:38 PM
man that's moving!
Nelson Taylor
posted November 07, 2007 03:51 PM
He is moving indeed...
I'm doing something wrong.
I need to take one of his classes.
Best #'s
1.54
4.03
6.02 @ 121mph
(Stock Wheelbase) 2006 ZX14
fastestbusaaround
I eat Fish...
posted November 07, 2007 04:01 PM
Uhhh -- read carefully guys...he did it with ONE TOOTH DOWN IN THE REAR and 21LBS of EXTRA weight and no PC3 either.
FYYFF!!!
fastest-14
Fastest -14
posted November 07, 2007 04:58 PM
One tooth down in the rear is nothing significant in a 1/8 or 1/4 mile, plus it gears the bike slightly higher, not lower which means that he won't be able to come out as quick as if he was down 1 tooth in the front, which most people do but take a tooth out of the rear will give rider slightly more top end, which is not important in an 1/8 mile track. If one tooth down in the rear is what Rickey did, that's kinda odd. Most people who drag race either go up however many teeth in the rear or down one in the front, if not both, which allows the bike to come out the hole quicker. Maybe they're are trying to keep it from wheeling too much in the front since it's on stock wheel base.
fastestbusaaround
I eat Fish...
posted November 07, 2007 05:05 PM
I know that -- thats why I mentioned he was down a tooth in the rear......so if he had left it stock, he'd be pulling harder out of the hole. As you said, less chance of wheeleing, hence his extra weight too. That was my point.
FYYFF!!!
fastest-14
Fastest -14
posted November 07, 2007 05:22 PM
I with ya. I wouldn't think that Rickey G. would be worrying about wheeling. Take the extra weight off and put it back to stock gearing, I bet he makes a faster pass, but he's the pro so...maybe he's just experimenting.
This goes to show you how fast and impressive that "08" 14 is, STOCK!
swiftkart
posted November 07, 2007 05:35 PM
Brock and several others are all running stock 17t front with 1 down 40t rear now on stcok wheel base zx14's and they are all running 9.0's in the 1/4, Rickey will be in the 8.9's stock wheel base this weekend.
smokinzx14
posted November 07, 2007 08:00 PM
Yep that 5.83 @ 126 will get him high 8.80s at 154+ in the 1/4 mile at Gainsville ...
warbird
posted November 07, 2007 08:08 PM
One tooth down in the rear moves the axle back ever so slightly.........................and that extra weight is up front somewhere I would presume. Both would help keep the front down...........
All the little things add up to good et's............right smokin?
smokinzx14
posted November 07, 2007 08:11 PM
Yes Sir you are correct ...Brock did the same thing to his 06 zx14 , he went to a 40 tooth on the rear to clam down the wheelies .. 21 pounds on the front end really helps ...Smokin..
Nelson Taylor
posted November 08, 2007 10:24 AM
Sounds like something to tryout next year.
Anyone know what he's using for weight?
Best #'s
1.54
4.03
6.02 @ 121mph
0.22988891601562 seconds processing time
