BIKELAND > FORUMS > ZX-14.com > Thread: Cam lift and duration for zx14 NEW TOPIC NEW POLL POST REPLY
supra5677
posted October 17, 2007 08:17 PM
Has anybody measured the stock cams for a zx12r yet...
supra
Y2KZX12R
CompetitionCNC.com
posted October 18, 2007 02:36 AM
You might want to call Megacycle or Web. I'm sure they know.
Y2KZX12R
CompetitionCNC.com
superchuck
posted October 18, 2007 05:09 AM
I take it you want the numbers on a 14's cams. I measured mine the lift on the intake was .355, exhaust was .335 lift. The manual says intake is 292 degrees duration,exhaust is 278 degrees. The exhaust is quite a bit smaller compared to a zx12's exhaust cam,mainly in duration. Hope this helps. Chuck
Halvefast
posted October 20, 2007 06:42 PM
So ??? Would the ZX14 benefit from replacing the exhaust cam with an intake?
More lift and duration? Similar to the popular Busa mod?
ECTA Ohio Mile 195.132mph
mink
posted October 21, 2007 12:39 AM
no worky cam sensor pickup is on exhaust cam
ZXLNT
posted October 21, 2007 01:15 AM
I thought the cam sensor bolts the cylinder head..
posted October 21, 2007 05:13 AM
yep, and the trigger is on the exh cam.
not a huge deal to put a trigger on an int cam.
supra5677
posted October 21, 2007 08:08 AM
stock zx12r cams .358in/ .342 ex duration at .050 244in./238 ex...
let me check the total duration on the exhaust..
supra5677
posted October 21, 2007 08:15 AM
zx12r uses 300 degrees on intake and 292 degrees on exhaust.. why use smaller cams and throttle bodies?
Halvefast
posted October 21, 2007 08:55 AM
Sooo ??? Would a ZX12R exhaust cam work in a 14?
ZXLNT
posted October 21, 2007 09:28 PM
Abt 99.99999999 percent sure, that would be a no..
supra5677
posted October 22, 2007 06:54 PM
the diameter of the bores are only 1mm difference..Actually I think they would work..
ZXLNT
posted October 22, 2007 11:10 PM
Diameter of what bores, the tappet bores? Are the Valve stem centers the same distance apart. What about lift/duration and what about the retaining cap diameter. I doubt very seriously the 12R cams would be even remotely close to working.
0.27006602287292 seconds processing time
