BIKELAND > FORUMS > ZX-14.com > Thread: Tire pressure? NEW TOPIC NEW POLL POST REPLY
cnote
posted October 16, 2007 06:31 PM
Tire pressure?
I got my bike setup for the track this coming Friday lowering links,front straps, and extension blocks did i forget anything else Anyway I was wondering where should my tire pressure be set at front and rear.
posted October 16, 2007 06:37 PM
run stock(42lbs) and see how it hooks then lower if necessary, are you running the orig tires?
ninja12
posted October 16, 2007 06:38 PM
max out the front tire and run as much as you can get to hook in the rear.
What is your wheelbase, tire type? Whats your weight?
posted October 16, 2007 06:44 PM
27 pounds front and rear. michelinpower full race tires, medium race compound, tire warmers HOT!
Photo Sharing and Video Hosting at Photobucket
cnote
posted October 16, 2007 07:51 PM
6 1/2" over stock' m1 tires weight 265 big boy
smokinzx14
posted October 16, 2007 08:04 PM
Front tire 50 psi ... Rear start at 17 psi ... if it spins drop to 15 psi .... if that doesn't work get a shinko 003 ultra soft ...Smokin..
smokinzx14
posted October 16, 2007 08:05 PM
OH good luck and have fun !!!!!!!!!! ...
ninja12
posted October 17, 2007 10:20 PM
go ahead and order the shinko ultra soft .
Us big guys need more traction to get out the hole.
0.21271514892578 seconds processing time
