BIKELAND > FORUMS > ZX-14.com > Thread: FI light NEW TOPIC NEW POLL POST REPLY
zxn4fun
posted October 12, 2007 02:09 AM
FI light
pulled the flies outta my bike a rode it around for a day , didnt like the heat range I was seeing in traffic, put the flies back in and got a FI light. Pulled the flies back out again but still have the f@!#@!g light. disconnected battery thinkin this would rest computer any body know how I can remove the FI code??
BobC
posted October 12, 2007 03:17 AM
Did you pull the flies without re-mapping the fuel injection? If so, that would be why it's running too hot, the mixture is weak at lower rpm. Hope you solve the FI problem, did something get unplugged or disturbed when you were in there?
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
Halvefast
posted October 12, 2007 04:46 AM
Check that your secondary shaft is moving freely when it goes into check mode when the key is first turned on.
I have heard of a few that have gotten bent when trying to remove stubborn fly screws.
One rider even moves his manually each time he starts the bike to turn off the light.
He leaves the 2 screws that hold the foreman grill on the leftside out so he can reach it by hand.
Best of luck
ECTA Ohio Mile 195.132mph
posted October 12, 2007 05:39 AM
+1
insure the PCIII is mapped for the flies-out
port_angeles_ninja
posted October 12, 2007 06:09 AM
To get the service code for the FI error
1) Turn the Ignition Switch ON
2) Push the Mode and Reset Buttons for more than 2 seconds
The 2 digit service code should then be displayed:
11- Main Throttle sensor malfunction, Wiring Open or short
32-Subthrottle sensor malfunction, Wiring Open or short
62-Subthrottle valve actuator malfunction, wiring open or short.
There's a bunch of other codes, but it's probably one of these 3.
Red/Black 85' GPZ900
Blue 07' ZX14
zxn4fun
posted October 12, 2007 01:05 PM
got a 62 code gonna try a couple of things or shoot the ecu if nothing else works
zxn4fun
posted October 12, 2007 03:36 PM
its fixed thanks to those that replied.......................Biketoberfest here i come!
KillaKAW4Life
posted October 12, 2007 04:31 PM
What was the prolem?
posted October 12, 2007 05:10 PM
hopefully I'll see you at Biketoberfest! I'll have my race bike there, not the ZX14.
ZXLNT
posted October 12, 2007 07:32 PM
He moved the sub throttle shaft when taking out the butterflys. Probably confused the ECU..
0.22932720184326 seconds processing time
