BIKELAND > FORUMS > ZX-14.com > Thread: Front Wheel Bearing NEW TOPIC NEW POLL POST REPLY
ghostman
posted October 04, 2007 04:10 PM
Front Wheel Bearing
Heard light squeeling from front wheel. Think it's the bearing. Has anybody else had this issue?
I'm There Whether You See Me Or Not.
SoCalZX
posted October 04, 2007 05:26 PM
Front brakes squeal at low speeds...were you at speed when you heard this?
lietoome
posted October 04, 2007 05:56 PM
helmet or no helmet? The reason I ask is because when I'm troubleshooting, I've gotta pull my lid off to help hear the noise. Without lid, you may be able to narrow it down.
Reaper
posted October 07, 2007 07:12 AM
I had it and I think I solved it when I changed the front tyre and slapped on some more high temp grease around the front axle, spacers, rubber seals and bearing cases..
My brakes sometimes squeak but I see that as a sign that the pistons aren't sticking and the pads are still able to move freely where they should, normally caused by a bit of brake dust or the pad vibrating against the pistons..
Reaper
2006 ZX-14
Ti-Force High mounts
PC III
No pesky flies
Katie: 2006 ZX-14.. 186.69HP 110.68ftlb,
Ti-Force Twin High mount Slip-ons, Hyperpro Steering Damper, Sato rearsets, Carbon Fibre Lowers, lower rear wing, Tank Pad, Hugger, Ohlins Road and Track Rear Shock, HID low beam, Sato Rearsets, ASV Levers, Goodridge Carbo-Line Braided front and rear Brake lines, Galfer Braided Clutch line, ZX-10 Front Fender, EK ZZZ Drive chain, Driven rear sprocket, Pipercross Race filter, Powercommander, Secondary Butterflys removed
posted October 07, 2007 07:39 AM
most likely front brakes at low speeds i done heard that
tater
Shakin off the Haters
posted October 12, 2007 08:47 AM        Edited By: tater on 12 Oct 2007 09:48
my front brakes squeal all the damn time
ZX-14 06
Flies out
-1 front, +2 rear
2 Bros carbon fiber pipes
Tiger tail
Carbon fiber windscreen
64inch wheel base
lowering links
RC components wheels
badzx14
needs more power!!!!!
posted October 12, 2007 11:40 AM
My rear brakes squeal every once in awhile but never had the fronts make any noise.
0.38021802902222 seconds processing time
