BIKELAND > FORUMS > ZX-14.com > Thread: autocom NEW TOPIC NEW POLL POST REPLY
prainger
posted September 30, 2007 02:24 AM
autocom
Hi all
Can anyone tell me the best way to wire in a autocom in to my new(3miles on the clock) zzr1400
GUNNER
posted September 30, 2007 03:32 PM
Use a relay for the 12V and switch it off of something like a tail lite bulb. Take the ground strait back to the battery. Run large wire for the ground and the 12V all the way to the relay.. If you don't do this you will get to learn the phrase DIRTY POWER
fastestbusaaround
I eat Fish...
posted October 01, 2007 04:15 PM
Easier than that -- run the power from the ignition switch -- use the ignition wire, no need to use a relay if you grab power from there. Ground to battery as the Gunman says, best place.
FYYFF!!!
prainger
posted October 03, 2007 11:02 AM
HI
Thanks for your replies. I found out today that under the seat there is a little fuse box that has a red and blue wire running from it. This wire is the one autocom recommend to link into.
pete
0.21785306930542 seconds processing time
