BIKELAND > FORUMS > ZX-14.com > Thread: My day/night at the track, part 8?? NEW TOPIC NEW POLL POST REPLY
iflyems
posted September 22, 2007 09:22 AM
Ok, if your in a hurry, and want the results, just scroll down.
Now a little history. I remember when I first started drag racing bikes, my first trip donw the track was an 11 something, and it happened so fast I don't remember shifting. After awhile, 11 seconds seemed slow. I remember I had time to stare at the tach, look in mirrors for my opponent, and basically sight see down the track. Then came the 10's, same thing, happened so fast I don't remember shifting.
Well now im in the 8's, and since I haven't ridden the bike in 4 months, I'm back to the "happened so fast" I don't remember shifting. I do remember looking at the boost gauge on all my passes, and I'm quite impressed with the external waste gate. It held exactly 10psi all the way down the track. My old internal waste gate would hold around 7 or 8psi, but would creep up to 14psi whe I got to around 11,000 rpm. Not this new waste gate....it never moved off 10, which is where I set it.
Now the track. It was pretty sticky, but little gummy balls where coming off the track because it was, after all, test n tune for everybody, including street tire cars, which tend to tear the rubber off the track.
The first pass, I had decided I was just gonna ride it down the track to break in the motor. I also wanted to make sure I had plenty of room in the shutdown area.
1# R/T: .070
60' 1.859
330' 4.431
1/8 6.334 @ 131.31mph
1000' 7.986
1/4 9.602 @ 128.73
The bike ran flawlessly, and it appeared that I had plenty of stopping distance. So the next pass I was gonna go balls out. The bike hooked up good. I had thought it might spin. I was having problems with the clutch engaging late in the lever throw. Before the rebuild, it would engage early in the throw, so consequently I was slipping the clutch way more than I needed too. But my 60's will improve with practice.
#2 R/T .143(zzzzzzz)
60' 1.702
330' 4.185
1/8 6.072 @ 133.33
1000' 7.646
1/4 8.994 @163.84
#3 R/T .069(yeehaw)
60' 1.717
330' 4.174
1/8 6.027 @ 133.82
1000' 7.616
1/4 8.962 @ 165.31
Track surface temp was 104 deg. Air temp was between 89 and 83 deg, and humidity was a steady 53%.
I had wanted to make more runs, and it was still early, when a car blew a radiator hose in the best lane, and he decided to run the car the whole lengh of the track, effectively ruining the right lane for the night. With over 150 cars in the lanes, there was no way I was going to make another pass, so I packed it up til the next time.
The bike handled and ran flawlessly, with one exception; It lifted the carried the front tire in 3rd, 4th, and 5th. Its never done that before, that I remembered. Each time it came down, it wiggled a bit, but I have a steering dampner so it wasn't a problem. It is a bit uncomfortable to have the front end start coming up at 130mph, not knowing where its going to stop, so on each of those runs, I went "soft" with the throttle. That is I just reduced the throttle a tiny bit so the front end wouldn't come up any highter.
I'm going to change the front sprocket to an 18 tooth(gearing now is 17/43), and go back to the 41 tooth rear. That should put me close to 64", the maximum lengh for ultra-street. Last night the bike was at 66".
My goal here is to see just how quick I can run the bike at 10psi. I see no reason to crank up the boost until I get a boost controller. The bike is a lot of fun to ride right now, and I feel at that boost pressure its safe on the motor, and it will last a long time.
Stage XXX Mr Turbo ZX14
posted September 22, 2007 09:40 AM
ifly,
good job getting to the 8's ton of eight mph and trap speed. if you can get your 60fts from 1.7s to 1.4s you will be around the 8.4 to 8.5s look forward to hearing more
XXX
jeff martin
Pro (closed)
jamming
posted September 22, 2007 09:41 AM
You guys who drag the 14 do you do any internal engine work.
i play with boats my wife plays with my dingy.
  Ignore this member    Click here to visit jeff martin's homepage.
smokinzx14
posted September 22, 2007 10:14 AM
Cool ... Great 1/8 MPH for no 60 foot at all ....Happy to see you back at the track ... Keep them numbers coming ..Smokin..
iflyems
posted September 22, 2007 10:30 AM
I did a ton of motor work too mine. If you plan on drag racing a turbo ZX14 you can pay now, or pay later....but your gonna pay. Plan on about $7000 worth of engine work, if you truly want reliability.
Thanks smokin.....I'll get there eventualy, just takes time....I only have 3 passes on the bike since I got it back. And before that, with the turbo, probably 20 passes, at the most.
tg1820
posted September 22, 2007 01:48 PM
Great first night! At this rate you will be in the low eight's running at only 10 pounds of boost! AWESOME!
TG1820
nightmare
ACP Racing
posted September 22, 2007 02:08 PM
Looks like we have a bad mutha fucka to look forward to reading about in the near future! Holy shit! you are running those 60' times and still getting into the eights. hurry up and learn to ride that thing again so we can see what she is completly capable of! Great job dawg!
2006 ZX14 Ninja "SWINE FLU"
60ft 1.23
8th Mile 5.16
ACP Racing
iflyems
posted September 22, 2007 02:43 PM
Yea..yea...I know, an electric wheelchair has a better 60' time....I'll get it thought
tg1820
posted September 22, 2007 02:48 PM
I only hope to do as well in my first three passes with the new setup!
iflyems
posted September 22, 2007 02:56 PM
Good luck....when are you going to run it??
ZXLNT
posted September 23, 2007 02:20 AM
Phil were you at KCIR???
Bring that bitch over to Topeka....
iflyems
posted September 23, 2007 04:13 AM
Might have to do that.....they have a race on a Wednesday, I think second one in October, might try it there. KCIR is not that bad....I was getting pretty good traction, and was able to stop easily on the track, plus its only an hour away, vs. 2 1/2 for HPT..
ZXLNT
posted September 23, 2007 05:42 AM
Let me know if U decided to come down, I'll come out..
iflyems
posted September 23, 2007 07:45 AM
Weds, October 3rd at KCIR will be my next "opportunity". Going to an 18t front before then.
0.2517831325531 seconds processing time
