tater
Shakin off the Haters
posted September 04, 2007 06:47 AM
vibrations going into turns
when ever i go into a turn right or left the bike shakes kinda bad, wondering if anyone has had this problem . I have checked the chain and its good. could it be the wheel bearings allready. i have 2500 miles on it. any sugestions ?
ZX-14 06
Flies out
-1 front, +2 rear
2 Bros carbon fiber pipes
Tiger tail
Carbon fiber windscreen
64inch wheel base
lowering links
RC components wheels
FasterThanStink
posted September 04, 2007 12:48 PM
I would start with the steering head bearing and see that it is adjusted properly.
That's what gets you.
Sticks_n_Stones
posted September 05, 2007 05:45 AM
quote: I would start with the steering head bearing and see that it is adjusted properly.
Yep that was my problem. I noticed the bike 'shifted' as I leaned either left or right from center. It was almost a thump but not quite. On the gas hard coming out of the corner it would do it again, very unsettling. Couldnt get it to do it at all when I was stopped or when I had front end hoisted, would only do it under load. I took off the top triple clamp and readjusted the steering head spanner nuts about 1 1/2 full turns to snug (don't know the torque). Seems to be fine now, but steering is a little heavier which is probably good since there aint no damper on the 14.
tater
posted September 05, 2007 06:39 AM
the vibrations are coming from the rear of the bike, gonna take it apart tonight, will keep everyone informed
Sticks_n_Stones
posted September 05, 2007 06:44 AM
Yeah my friend (a bike mechanic) thought it was the rear initially too. Hope it's something simple and DO NOT STOP until you find it because you never want to ignore something involving the suspension/tires. you only got 2!
tater
posted September 05, 2007 06:55 AM
i apprectate all the help well let you guys know the deatils tommorrow
tater
posted September 06, 2007 06:23 AM
well we riped her down last night and we could not find anything loose, so i took it for a quick ride and it seemed normal and i could not get it to reproduced the vibrations, so i will keep playing with it till it does it again.
