BIKELAND > FORUMS > ZX-14.com > Thread: clutch problems NEW TOPIC NEW POLL POST REPLY
BADBOYINDC
2007 ZX14 Black
posted August 24, 2007 05:00 AM
clutch problems
ok first i have 07 fast blk
Hers is my problem I have 3800 miles on my 14 and the clutch is slipping
can that be true i have draged it a few time but not to mess the clutches up
well do you all think something wrong inside or should i just take the clutches out and replace them or take it to the dealer and see what they can do for me
one more thing is it hard to change the clutches
please help me out
Brock exhust 16/45 sprockets,
Nos, Mactosh arm 8inches over
Powercammander ajustable lowering links airshifter all the good shit Crome Rc wheels
LET IT DO WHAT IT GOING TO DO
buddy
posted August 24, 2007 05:27 AM
It's not hard to change a clutch for someone who has changed a few. If it is your first attempt, you should probably have a manual available. The manual has a good section on the clutch and how to inspect it for problems, and if necessary, change it.
BADBOYINDC
2007 ZX14 Black
posted August 24, 2007 06:24 AM
thanks buddy man this racing can cost you a lot of down time and money but if you want to go fast you have to break sometimes
dutchzx14
posted August 24, 2007 06:29 AM
Had the same problem also. changed the oil and it was oke again...
  Ignore this member    Click here to visit dutchzx14's homepage.
BADBOYINDC
2007 ZX14 Black
posted August 24, 2007 06:52 AM
thanks for the help guys i will order clutches today know of a good place to order from that would not cost a arm and a leg
ninja12
posted August 24, 2007 07:12 AM
RonAyers.com is usually pretty good with pricing.
jdzx14
posted August 24, 2007 07:26 AM
Hey man, I just went through this. First off as far as changing them its easy. First take the lower faring off, second drain the oil and filter, third take the cover off, fourth 5 bolts w/springs, fifth get 2 small screw drivers or something small to grab plates and discs and slide them out. Then reverse the steps. Just take your time and make sure to lay everything out so it goes back the way it came out. I got my fibers from snhizt racing, for about 113.00 shipped to me. They are OEM so there good quality.
BADBOYINDC
2007 ZX14 Black
posted August 24, 2007 07:30 AM
so you did not have to change the steels
Pat Dietrich
posted August 24, 2007 08:01 AM
You only change steels if there warped. Unless you slide your clutch hard off the line they are probably fine. The other thing is more than likely you can keep your bike leaned over on the kick stand and not worry about draining the oil. I've never taken oil out to mess with the clutch.
BADBOYINDC
2007 ZX14 Black
posted August 24, 2007 08:21 AM        Edited By: BADBOYINDC on 24 Aug 2007 09:25
ok that is cool but i need to change it any way so that a good thing the dealer want to $290 for the clutches and steels i told them to kiss my $$$ lol that is to much when i can order them online for $179 for all of them
Pat Dietrich
posted August 24, 2007 09:37 AM
i used to get oem parts from xtreme suzuki for 20 % lower than ron ayers. Not sure if they sell Kaw parts yet but i'll find out soon
BADBOYINDC
2007 ZX14 Black
posted August 24, 2007 09:53 AM
OK COOL LET ME KNOW
Sticks_n_Stones
posted August 24, 2007 12:33 PM
Stop and try that my friend you could be wasting money. I've had that happen on both my TL1000R and my ZX6 (1988). Both times it was because I changed to the wrong oil- one time to Mobil 1 synthetic and once to an ATV oil I believe. I changed oil back to OEM and it resumed operation properly. I put 12000 more miles and counting on my TLR since then, too. So try the obvious first, oil changes never hurt anyways! Good luck and keep the green in your pocket!
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
Zombie Dan 14
posted August 24, 2007 06:11 PM
May be stating the obvious, using correct oil ? Not oil with energy conserving additives (car oil)
  Ignore this member    Click here to visit Zombie Dan 14's homepage.
Pat Dietrich
posted August 24, 2007 06:27 PM
Mobile 1 gold cap car oil is perfectly fine for bikes and its car oil. If your clutches start slipping and it glazes the fibers, your NOT going to change oil and fix it. Change the freakin' fibers and be done with it. If I burn up a piston can I just change the brand of fuel I use ?? hehehe
posted August 25, 2007 07:25 AM
"Mobile 1 gold cap car oil is perfectly fine for bikes and its car oil."
they changed the formula, the bulletin on brocks site warns about damaged clutches from the mobil 07 formula FYI
Pat Dietrich
posted August 25, 2007 09:12 AM
whats the 07 formula?
Synthetic however will wear on the clutches faster .
Sticks_n_Stones
posted August 25, 2007 11:02 AM
07 as in 2007 year. How do you figure that synthetic will wear out clutches faster? Found this at the Amsoil website
Quote:Petroleum oils have low resistance to heat and allow varnish and glaze to form on clutch plates, which can lead to slippage and increased heat generation and potential failure of the clutch pack. Synthetic oil is going to allow your wet clutches to perform better (especially under extreme heat, RPM and load conditions) and last longer than they would with petroleum oil subjected to the same operational conditions.
http://www.performanceoiltechnology.com/syntheticsslipperinessandwetclutches.htm
also found this test: car verse motorcycle oil - mobile 1 wins (circa 1994 before synthetic motorcycle oil)
http://www.xs11.com/stories/mcnoil94.htm
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
0.22041201591492 seconds processing time
