BIKELAND > FORUMS > ZX-14.com > Thread: chain links anyone? NEW TOPIC NEW POLL POST REPLY
johnsonzx14
posted August 20, 2007 02:03 PM
chain links anyone?
Whats up guys, does anyone have any stock chain links I can buy, Im about to put my extended swingarm on and need enough links to make it 3 to 4 inches over... let me know, thanks
BlackMagic14
posted August 20, 2007 09:01 PM
I will sell you my stock chain as a whole but I have no idea what it is worth, either way let me know cause I was thinking of keeping it as a back up
blackbullet76
posted August 21, 2007 05:11 AM
Im thinking of getting some swingarm extensions for my 14, but only installing them for the track and removing them for street riding. I want to put a master link in my stock chain and my extended chain for quick removal and installation. Anybody on here doing that? Will the stock rear brake line have enough slack to make this wrok without having to change it out as well?
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
flatoutbu
posted August 21, 2007 07:39 AM
Your brake line will work....all you have to do is take the line off and face it backwards and it will give you alot more slack. If you get a small hunk of chain you can run 2 master links and be able to shorten and lengthen your chain as ya like. I personally dont like running 2 master links, but guys do it all the time with no problems.
06 Blue 14
9.008 at 153mph @ 195 suited
MasterBlaster
posted August 21, 2007 11:21 AM
A tip, buy the master links from Suzuki, at least here theirs were better than the ones Honda/Kaw sells, more robust......TB
blackbullet76
posted August 23, 2007 05:27 AM
I'd rather run a different chain, just to be safe.
After I do this, can I leave the line like that when I take the extensions off?
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
flatoutbu
posted August 23, 2007 07:38 AM
yes but you will have alot of slack in the line....
06 Blue 14
johnsonzx14
posted August 26, 2007 12:24 PM
Whats up guys, How much is a good chain... I cant decide on buying links, or just get a new chain.. I am going four over so how many links is that.. Does anyone know?
flatoutbu
posted August 27, 2007 05:02 AM
my EK chains run around 140-150 bucks depending on length. You won't need anything bigger than 120 links at the most. I use only EK's but there are alot of good chains out there. With 4 over you should just buy another chain. I run non o-ring chains but their alittle louder and require lube more often....but lighter than a o-ring chain.
06 Blue 14
johnsonzx14
posted August 28, 2007 02:17 PM
ok sweet... Ill probably get one of those... Oh, my swing arm looks bad ass too..ill put pics up soon..
0.30290603637695 seconds processing time
