BIKELAND > FORUMS > ZX-14.com > Thread: Speedohealer survey NEW TOPIC NEW POLL POST REPLY
posted August 19, 2007 06:53 PM
Speedohealer survey
I know some have posted their speedohealer settings in previous posts, but for stock gearing where do you have your correction set at?
I just installed my speedohealer set at -10% to start. I will check with the GPS when time permits.
posted August 19, 2007 09:01 PM
- 8 % stock gears new tire, to correct readings to real world 186mph/300k
-18% for real world 204 mph speed limited, knowing the speedo is reading low 10 % at all times...
BobC
posted August 20, 2007 04:25 AM
I always assumed -7% to be about right but at the moment I'm running 17/40 gearing which is about 2.5% up, so I have the SH in transparent mode. Keeps me the right side of the law.
For the track I set it to "convert kph to mph" and read mph off the inner scale of the speedo while it defeats the limiter for me.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
posted August 21, 2007 06:16 PM
only two healer owners out there?
posted August 21, 2007 06:24 PM
I use GPS for speed, that speedo on the 14 is way way off.
Dave this is off-topic, but if Brigitte is on the back of the bike next time you see me, her ask her how fast my GPS said we were doing as we were leaning in the off-ramp turn 275 going onto Ulmerton
Nothing like pilot powers for 2-up speed in the turns :P
blackbullet76
posted August 22, 2007 07:10 AM
I don't remember my percentage, but I set it for best compromise. From the gas station to the house it used to show 5.1 miles stock. I changed my front sprocket to a 16t and installed the SH, now it shows 4.9 miles.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
posted August 26, 2007 05:34 PM
i just set it to -8% seems close. the gear indicator is acting a little squirrely, sluggish. i do like the speedo to read right tho.
posted August 26, 2007 05:37 PM
ZUMO 550 GPS for accuracy :P
posted August 26, 2007 05:57 PM
i have a handheld garmin, need to take it for a ride , or just ride with you
posted August 26, 2007 06:07 PM
we're way overdue to go riding anyway
xtro
posted August 27, 2007 08:44 AM
16t 43t and -6 or 7 or 8 or sumthin.. Zumo550 as well .. so close I can't tell the difference
saves a few kms on th odo. . and I know when I'll be getting the 10,000 when in Ont.
posted August 27, 2007 09:31 AM
...and I know when I'll be getting the 10,000 when in Ont.
LMAO
TJ
posted August 30, 2007 12:54 PM
My bike was 7% off at 60 mph with stock gearing.
0.26132988929749 seconds processing time
