BIKELAND > FORUMS > ZX-14.com > Thread: adjustable lowering links NEW TOPIC NEW POLL POST REPLY
creeker
posted August 18, 2007 05:55 PM
new member,been around since july ,06. installing adj. links,measured them 1.5 ins.longer,now oil plug has 2 ins. clearence ,lowered the front 1.5 ins. is this okay for normal rideing. thanks
posted August 18, 2007 07:46 PM
2 inches is really low, speed bumps, pot holes , shit, just braking over bumps could drive it into the pavement...
I wouldn't go that low on the street,
infact that is the minimum clearance we must run on our bikes for Canadian drag racing series!
FasterThanStink
posted August 18, 2007 09:13 PM
Here is what can happen if you go to low:
http://www.bikeland.org/board/viewthread.php?FID=27&TID=33678&set_time=
That's what gets you.
creeker
posted August 18, 2007 09:56 PM
what is good clearence?
MasterBlaster
posted August 19, 2007 10:13 AM
I dropped mine 1 in front and rear, and still broke the protective casting in front of the drain plug. Am lots more careful now but still manage to scrape it now and again. I did put on extensions without changing the rear adjustment, so it lifted it probably back to stock heighth, helping some.....TB
BobC
posted August 20, 2007 05:46 AM
I dropped the front one centimetre, 0.4 inches and for road riding I leave it like that with the rear end at standard height.
At the track I strap the front right down and lower the rear three inches. If you want to ride on the road at that height you need to modify the sump or you're going to rip the drain plug off.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
0.30508399009705 seconds processing time
