BIKELAND > FORUMS > ZX-14.com > Thread: What chain to use? NEW TOPIC NEW POLL POST REPLY
Norcal14
posted August 06, 2007 07:11 AM
What chain to use?
Just purchased the roaring toys extensions and was wondering what chain people were using and how many links. Who has the best deals. Any info would be great.
06 Black 14
Brock Gen 3
No Flies
PC3
Fender Eliminator
smokinzx14
posted August 06, 2007 08:08 AM
Schnitz racing dzr2 none oring 150 links .... about 110 bucks ....
mark524
posted August 06, 2007 01:14 PM
hey smokin
do the non oring chain stretch more and require adjustment more often? do you street ride with one?
Bently
2012 14r In Blue and no Mods!
posted August 06, 2007 02:39 PM
Mark you can ride on the street with it but you will have to adjust it more then a o ring chain and it will wear out quicker as well. And if riding on the street lube it more often then a o ring chain.
mark524
posted August 06, 2007 07:33 PM
thanks, I've been riding with it a little, seems to need adjusted more often. I'm loving those extensions. Going to the track Thursday.
BobC
posted August 07, 2007 02:47 AM
Does anyone know how much power an O'ring chain actually absorbs at speed?
I have been thinking about some race chain for when I need to replace my bikes original chain. Every single bhp counts.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
posted August 07, 2007 04:32 AM
at top speed probably 2-4 rwhp is lost due to friction of o ring,
If your going that distance then don't forget to remove he air fliter, MR9 or U4 fuel, 0 weight oil, 50 psi in the frt tire, remove 1 frt disc, lighweight seat, and ceramic wheels brgs!
tslewisz
posted August 07, 2007 06:57 AM
I remember a question on Schnitz's old forum - somebody asking how much faster he'd go in the quarter going to a non-O-ring chain. Ryan responded that after the burnout, the chain is hot and it doesn't make any difference. YMMV, I guess.
BobC
posted August 07, 2007 08:13 AM        Edited By: BobC on 7 Aug 2007 09:14
I won't be doing a burn out for top speed events. Have already modded filter and use 5w30 Rock Oil Synthesis XRP fully synthetic.
Your right Dubious, attention to all the small details is what makes a winner. For top speed events good aerodynamics is as important as engine power, I'm looking for a seat and tank from a written off bike so I can cut them down and tuck in some more.
Sorry if this is off-topic.
Stock wheelbase
flatoutbu
posted August 07, 2007 08:26 AM
Bob why dont you buy a catalyst seat and use it. You sit waaaay lower in the bike and i'm assuming the aero's would be better....i'm not a top speed guy so i'm guessing. I just bought a used seat off ebay for $135 believe it or not that's alot cheaper than i can get at dealer cost. You could also switch to a 525 conversion if ya wanted for a little less weight.
Now to the post.....I use a ek530drz....good chain. Lube it often and check your tension, and you'll be golden.
06 Blue 14
9.008 at 153mph @ 195 suited
0.26045894622803 seconds processing time
