BIKELAND > FORUMS > ZX-14.com > Thread: multi-hub NEW TOPIC NEW POLL POST REPLY
1badzx12r
posted July 28, 2007 01:10 PM
multi-hub
ok downloaded firmware for multi-hub ..went by DJET instructions for install...everything was going ok ...then as installing at about 20% it shuts down...ok... now I've got a dead pc3 that is not sending info back to control center.... control center reads in right hand corner NO POWER COMMANDER.... WTF I can see it there ...its hooked up to it with USB cables.... and i downloaded the latest control center
1badzx12r
posted July 28, 2007 01:11 PM
oh and i take it dyno-jet is closed on saturdays....cuz their fukking phones no works either
posted July 28, 2007 01:46 PM
hey just as a WTF- did you try removing the cables from everywhere, recycling the power on the djet and rebooting the puter... then cabling everything back up. My djet got hosed and that worked for me
1badzx12r
posted July 28, 2007 01:55 PM
working on that right now
1badzx12r
posted July 28, 2007 03:13 PM
nope no work..... so i take that POS of and package it up really nice for them....run on stock settings and if it runs better....i'm not putting it back on
1badzx12r
posted July 28, 2007 03:20 PM
bike allready idle's better without that POS
1badzx12r
posted July 28, 2007 05:55 PM
well i fixed it.....
smokinzx14
posted July 28, 2007 06:17 PM
Same thing happened to Jesse and me when we tried to install his lcd unit .... But some how we fried the P/C ... Jesse had to send the P/C back to dyno jet to be repaired ...
posted July 28, 2007 07:03 PM        Edited By: bigdtd on 28 Jul 2007 20:08
i had to update the firmware on the pclll for it to work with the lcd. thats the problem. update the pclll firmware and your stuff will work. dynojet site has the files. also if you are doing it on the bike you need to use the external 9v battery because during the firmware update it interrupts the bike power if you try it that way.
1badzx12r
posted July 28, 2007 07:46 PM        Edited By: 1badzx12r on 28 Jul 2007 20:48
i had to update the firmware on the pclll for it to work with the LCD. that's the problem. update the pclll firmware and your stuff will work. dynojet site has the files. also if you are doing it on the bike you need to use the external 9v battery because during the firmware update it interrupts the bike power if you try it that way.
yeap i tried the 1st install on the bike and it got to 20% and shut down....then the pc3 did not respond like it wasn't hooked up...then i plugged the 9v to it while still on bike with power off...no luck this was with laptop and 9v setup.....then i removed pc3 from bike to bring in house to hook up to desk top... so i sat in A/C and keep reading djets instruction on how to install the download firmware...and keep working by djets instruction to no avail... keep getting codes that stopped all work....then i did it my way by just playing with windows 3 hrs no less... finally it took the firmware 100% download and everything came back up online... so a pc3 can run without the multi-hub with the firmware installed and it should...cuz now in the tools tab its got the tabs for multi-hub but gray when installed it should lite up black... like the ACC PUMP feature when disabled .....i was only getting a head start for my multi-hub setup on Tuesday....you know plug and play WTF that ever means......BUT somewhere in djet 's instructions is a screwup......SMOKEY you is a 100% correct it acts as if iPC3 fried but it wasn't
posted July 29, 2007 04:48 AM
glad you got it working, sometimes you got to earn it
0.33235001564026 seconds processing time
