BIKELAND > FORUMS > ZX-14.com > Thread: clutch NEW TOPIC NEW POLL POST REPLY
sportinglife
posted July 22, 2007 10:22 PM
clutch
I'm new here! Hello all-hope your zx's are doing great. I've got a question about bleeding the clutch line. Got a new Master cyl. The line was emptied from the previous mishap(tore the reservoir off and opened the line). I replaced unit with a new one-followed the manual to fill and bleed. It apparently has pressure at this time-but when I had the line on the bleed valve(on the master)and closed it-air was escaping from the closed valve. Is this NORMAL!!!? Thanks all.
0.32525897026062 seconds processing time
