BIKELAND > FORUMS > ZX-14.com > Thread: mtc lock up NEW TOPIC NEW POLL POST REPLY
1969ca
posted July 05, 2007 10:36 PM
mtc lock up
i have a molti stage lock up and tring to get it set up do you leave the chatter rings in or take them out i get the gap i need with them out but not with them in what do you guys think thanks for your time
salsa1
posted July 06, 2007 05:26 AM
Hello mr. 1969ca; what ever happened to your ZX-10R? sold it? do you still have a lockup clutch for it?
Thanks.
Salsa1
flatoutbu
posted July 06, 2007 08:56 AM
MTC calls for .100-.125 space between the fingers and the pressure plate. If you remove the chatter rings and replace the fibers with all zx11 fibers you will get the correct spacing. The problem with that is..a very short stack hight and a very short clutch throw. i'm working on using the thicker 2.9 steels and spacing the lock-up off the pressure plate to get the correct spacing. I'll let you know how they work
06 Blue 14
9.008 at 153mph @ 195 suited
1969ca
posted July 06, 2007 10:45 AM
salsa1 sold the lockup still have the 10 use it for the street and 14 for the track
0.24303507804871 seconds processing time
