BIKELAND > FORUMS > ZX-14.com > Thread: Mapping for no flies, open exhaust NEW TOPIC NEW POLL POST REPLY
hardcoremass
Powerhouse
posted July 05, 2007 05:30 PM
I plan on removing flies and possibly running open exhaust. Is there a PC/// map out there for this set-up. Are there any other concerns with removing any restriction, will backpressure be a problem? Not concerned about noise. Was wondering if Brock would have appropriate map...
07 zx14 (black), flies removed, BMC race filter, Muzzys M10, PClll, PC ignition module, RT ext, Muzzy lowering links, 40 shot spray
posted July 05, 2007 05:50 PM
Open exhaust is a bad idea. Can you say 'burned valves'?? Thot so!
hardcoremass
Powerhouse
posted July 05, 2007 05:58 PM
Why is it that you see so many manufacturers producing megaphone pipes with removable baffles. Does the megaphone allow for this? Was going to allow for about 12" of pipe after header condensor. Appreciate all advice, kind of new to the technical aspect of sportbikes, custom v-twin builder for years.
hardcoremass
Powerhouse
posted July 05, 2007 06:25 PM
Will someone chime in. Been running a KZ 1000 with modified 350 Chevy headers for approx 5000 hard miles, top end looks great. Is there any reason that you cannot run a zx 14 with open exhaust as long as you have enough backpressure???
jdzx14
posted July 05, 2007 06:29 PM
As long as you have enough pipe off the head to keep cold air from suckin back in you should be fine, but why just pipe, you are probly gonna lose HP and it will sound like ass!
hardcoremass
Powerhouse
posted July 05, 2007 06:36 PM
Very curious about HP loss with open exhaust, as far as the sound, kind of like that throaty tone, I guess its what trips my trigger>>>
BlackMagic14
posted July 05, 2007 08:58 PM
it will be TOO LOUD just get the street megaphone from Brocks
blackbullet76
posted July 07, 2007 04:59 AM
Isn't the street meg with the baffle out the same thing as running open exhaust?
posted July 08, 2007 04:27 PM
could be, just get your stuff from brock , then no worries, no shit , just great support, and then some
V2K_CCTX
posted July 10, 2007 06:43 AM
hardcoremass,
Guess all the hype about stripped and dropped screws...had me somewhat worried that I was going to trash me new bike, but just go ahead and do it.
Getting thru all the plastic fairings etc was hardest part.
Installed the PC3 in conjunction with the fly removal.
Run the bike up to warm, like for an oil change.
Pull all the fairing crap off as desribed throughout the forum. Get a 8" #2 philips screwdriver. A high quality brand new one. Get a magnetizer and magetize it. Have a retreaval magnet handy too. Place the screw driver in position and using a rubber mallet, rap it three or four times firmly. Then slowly loosen the screw. Loosen all eight before removing, that way if you do run into trouble, you can simple tighten back down.. I used a 6" pair of needle nose to pull the plates out. Took longer to pull the fairings, tank, etc, then to do the job.
Leo Vince 4-2 installed with PC3 (mapped by Motofuel) and NO Flies
V2K_CCTX:
2007 ZX-14 Ebony Black (his) -- Leo Vince exhaust/flies out/PC3 mapped/SS brake and clutch lines/helibars/Competition Werkes GP pegs F&R/Puig Carbon Fiber Windscreen/Bikelites fender eliminator/custom CNC frame sliders & fork sliders
2007 CBR600RR Pearl White/Silver (hers)
2007 GV650 Avitar (hers)
2007 Vulcan 2000 LT (his) Muzzy Drag Pipes/Kuryakyn ProR Hypercharger/PC3 mapped/Chrome everywhere/everything
2007 Ninja 250R Silver (daughters) w/ Muzzy SS Exhaust
0.23271298408508 seconds processing time
