BIKELAND > FORUMS > ZX-14.com > Thread: ? for those running single dry n2o nozzle NEW TOPIC NEW POLL POST REPLY
Xtremespeed
posted July 01, 2007 12:18 PM
Where are you mounting the nozzle on your 14. I'm a little worried about getting an even distribution.
SteddyTeddy
posted July 01, 2007 12:25 PM
PM Smokingzx14 or TonyTooth.
nightmare
ACP Racing
posted July 01, 2007 12:31 PM
My nozzles are in the air box right above the flies. One is in the center of 1 and 2 and the other is in the middle of 3 and 4
2006 ZX14 Ninja "SWINE FLU"
60ft 1.23
8th Mile 5.16
ACP Racing
Xtremespeed
posted July 01, 2007 12:52 PM
That's what I'm worried about. I only have one.
smokinzx14
posted July 01, 2007 02:12 PM
I'm running two nozzles ..One in each ram air tube ...Smokin
jarhead
posted July 01, 2007 09:52 PM
I am only running a single and have it mounted on the access plate on the throttle side, per Muzzy directions. I had the same concerns you do so I ask Ryan, he said when he mapped the bike he took temp readings on each pipe and they were good. He said there is so much air coming in and swirling so fast that this is a good place to go with it.
Hope this helps..
Xtremespeed
posted July 02, 2007 03:15 PM
Thanks. That is what I was looking for. I knew there were some kits out there with a single nozzle, but I didn't know where people were mounting them.
How do you have the nozzle pointed?
Xtremespeed
posted July 04, 2007 12:47 PM
Can someone tell me the suggested way to point the nozzle. How does Muzzy's recommend it?
1badzx12r
posted July 04, 2007 07:55 PM
i ran mine up thru the breather tube....no nozzle strait hose end
Xtremespeed
posted July 05, 2007 12:14 PM
I may try that. What jet size for 30 and 40hp?
0.21436905860901 seconds processing time
