BIKELAND > FORUMS > ZX-14.com > Thread: secondary cooling fan NEW TOPIC NEW POLL POST REPLY
vtxtc
posted June 27, 2007 03:12 PM
I am going to order a aftermarket 6.5 inch pull type cooling fan from spalusa, I would like to run it seperate of factory fan and control it with a toggle switch-question is what power supply would be recommended? I will be running a inline relay and won't power only when key on.
Wheelie
Old Man
posted June 27, 2007 03:13 PM
just turn your hazard switch into an on off fan switch for the oem fan. wee
ninja_knight
posted June 27, 2007 03:38 PM
That is a great idea VTXTC. Have you thought about wiring the two fans together then doing the hazard switch mod?
vtxtc
posted June 27, 2007 06:39 PM
Wiring into the emergency hazard switch is a great idea which I will use, I do wan't to keep the fans seperate so I will not be piggybacking- I like the ability to turn on secondary fan at my discretion,again thanks for the help and will post pictures and review when done.
posted June 27, 2007 06:56 PM
I'm glad my 14 doesn't overheat in these scorching Florida summers. Fortunately I don't even concern myself with the bike's performance regarding heat.
FasterThanStink
posted June 27, 2007 07:10 PM
I'm going to try switching to full synthetic oil and add water wetter this weekend. Lucky it cooled off to mid 80's for a few days. Since I live very close to downtown any ride I do has more than a few stop and go city miles in traffic.
Kawi should have had two fans on that monster radiator from the factory.
That's what gets you.
posted June 27, 2007 07:17 PM
the new 'busa has dual fans.
FasterThanStink
posted June 27, 2007 07:39 PM
Then I better add two more fans to be one step ahead.
posted June 27, 2007 07:41 PM
uhmm ok I wasn't quite expecting such an answer
ninja_knight
posted June 27, 2007 08:19 PM
Whoa! Are you serious??? Are you certain? That changes EVERYTHING!!!! Kawasaki just give up.... you are officially out of the competition now.
0.36442685127258 seconds processing time
