BIKELAND > FORUMS > ZX-14.com > Thread: best 1/4 pass? NEW TOPIC NEW POLL POST REPLY
Imustbenuts
posted June 26, 2007 05:39 PM
best 1/4 pass?
I'm looking for some feedback on what some of you are running in the quarter.
I'm in my first year at the track and can't break a 9.65.
06 14, muzzy air shifter 7-9" extensions,power commander,flies out, hindle (Brock) Sidewinder, 1 down in the front and 3 up in back, strapped and lowered 3" and I'm about 220lbs.
Any other mods? I need to keep it streetable too.
kawasaki_rick
posted June 26, 2007 05:59 PM
I dont think you need that much gear. I got about the same things as you. best 9.48 on engine.
Bently
2012 14r In Blue and no Mods!
posted June 26, 2007 06:13 PM
I'm 215 unsuited and have been 9.18 with Brock Smeg and 63 inches long, stock gearing.
BlackMagic14
posted June 26, 2007 07:37 PM
I agree that is to much gear 16/42 should be about right? what are your short times? that doesnt sound right at all with that setup at 220 pounds with some mid 1.40 60 foot times you should be running 9.20's to 9/teens
Nelson Taylor
posted June 26, 2007 08:42 PM
I'm 200lbs suited and have been as quick as 9.53 with stock pipes, stock gearing, airshifter and stock wheelbase. I usually run consistent 9.6's and 9.7's especially with this air being so bad now. I believe you need to feed it more throttle. If your 330's aren't around the 3.9 to 4.0's you arent getting on the throttle fast enough.
NT
Best #'s
1.54
4.03
6.02 @ 121mph
(Stock Wheelbase) 2006 ZX14
0.24358296394348 seconds processing time
