BIKELAND > FORUMS > ZX-14.com > Thread: Problems bleeding Rear Brake NEW TOPIC NEW POLL POST REPLY
hardcoremass
Powerhouse
posted June 26, 2007 05:18 PM
I installed a set of RT swingarm ext and had to remove rear brake line. Bled line as follows: Opened resevoir, filled with DOT 4 fluid, pumped brake lever several times and closed resevoir cover. Repeatedly pumped lever, held, and cracked both bleed screws, one followed by priming lever, and cracked second screw. After completing this approx 5 times with no air present, rode bike. Has mininal stopping power...... Is there something that I missed?
07 zx14 (black), flies removed, BMC race filter, Muzzys M10, PClll, PC ignition module, RT ext, Muzzy lowering links, 40 shot spray
Wheelie
Old Man
posted June 26, 2007 05:20 PM
burp it at the master cylinder? wee
ZXGRIFF
posted June 26, 2007 07:00 PM
Get a "mityvac" vacuum pump kit $70 from Sears. Made my brake bleeding a breeze!
posted June 27, 2007 04:22 AM        Edited By: dubious on 27 Jun 2007 05:22
tie the caliper to the ceiling with rope or whatever, keeping it positioned above the master cylinder will force the air uo to the bleeds rather than trying to push around the high spot in the line then down to the calipers. Yes mightyvac will definatly help.
V2K_CCTX
posted June 27, 2007 04:56 AM
Good data,
swapping my stock lines to braided steel and this would have helped.
will annotate in my log for next brake fluid change. Thanks
V2K_CCTX:
2007 ZX-14 Ebony Black (his) -- Leo Vince exhaust/flies out/PC3 mapped/SS brake and clutch lines/helibars/Competition Werkes GP pegs F&R/Puig Carbon Fiber Windscreen/Bikelites fender eliminator/custom CNC frame sliders & fork sliders
2007 CBR600RR Pearl White/Silver (hers)
2007 GV650 Avitar (hers)
2007 Vulcan 2000 LT (his) Muzzy Drag Pipes/Kuryakyn ProR Hypercharger/PC3 mapped/Chrome everywhere/everything
2007 Ninja 250R Silver (daughters) w/ Muzzy SS Exhaust
hardcoremass
Powerhouse
posted June 27, 2007 02:40 PM
Well wheelie, I opened resevoir cover and pumped lever, then replaced cover. This seemed to help some but stopping is still weak. I dont have a mightyvac available here in the hills, are there any other suggestions? I thought it would be an easy procedure. What is the reason behind having two bleed screws on the caliper...
0.27370190620422 seconds processing time
