BIKELAND > FORUMS > ZX-14.com > Thread: Sprocket Size NEW TOPIC NEW POLL POST REPLY
wikidzx-14
posted June 25, 2007 08:55 AM        Edited By: wikidzx-14 on 25 Jun 2007 09:57
Sprocket Size
Could anyone tell me what the best combo of sprocket is for the ZX-14 to get the best low end grunt. I don't care about the top speed as much as I do about the takeoff.
zx14mike
posted June 25, 2007 04:01 PM
16/42 is perfect WAY MORE grunt, acceleration and power and still cruises decent without being too buzzy on the highway, I did this mod at 200 miles and would never go back.
wikidzx-14
posted June 25, 2007 04:57 PM
did you have to change the size of the chain you used?
zx14mike
posted June 25, 2007 05:04 PM
Nope, stop chain works fine............16/42 is roughly same wheelbase as stock, while 16/41 is slightly longer wheelbase and 16/43 is slightly shorter wheelbase (wheel adjusted all the way forward)
fastestbusaaround
I eat Fish...
posted June 25, 2007 06:57 PM
Low end grunt -- you gotta pull the flies 1st. That will give you way more than sprockets to start.
FYYFF!!!
FasterThanStink
posted June 25, 2007 07:05 PM
I have a lot of low end grunt after I eat a couple of bean burritos at Taco Bell.
That's what gets you.
fastestbusaaround
I eat Fish...
posted June 25, 2007 07:21 PM
:d
FYYFF!!!
zx14mike
posted June 25, 2007 07:32 PM
He's right pulling te flies is a must do..........but the gearing also helps to unleash the beast.
wikidzx-14
posted June 26, 2007 06:22 AM
with pulling the flies I read that you can have issues with heating and possible stalling. Or is this only when you add a full exhaust without a PCIII and not a propper map?
Black 07 ZX-14, Stretched to 64", Lowered 1 1/2", Brocks SMEG, Flies removed, PCIII, Brocks Map, 200/50/17 rear tire, 16/43 gears, Heli Risers, Tobin Seat, Fender Elim,
flatoutbu
posted June 26, 2007 06:34 AM
if you plan on pulling the flies you will need a pc and remap.....and yes it is worth it. There is no other mod next to nitrous that will give you the same result...exhaust is a close2nd.
06 Blue 14
9.008 at 153mph @ 195 suited
wikidzx-14
posted June 26, 2007 01:21 PM
thanks guys for the info looks like I'll have to purchase the PCIII and put it in with the maps and pull the flies as well. Looks like exhust will come a bit later
0.2194139957428 seconds processing time
