BIKELAND > FORUMS > ZX-14.com > Thread: GALFER WAVES 320mm FOR THE 14 NEW TOPIC NEW POLL POST REPLY
zx1kr
posted June 20, 2007 04:31 PM
Galfer no longer makes OEM sized rotors for the 14 anymore. They are now 320mm and cost an extra $60.00+ for the spacer kit that MUST be used to accomodate these rotors. The upside is these rotors should give a substantial bump in the performance of already great brakes. Problem is, they're gonna hide even more on the BST Carbon wheel! Hopefully I'll pull another pound or two off the front wheel with them.
I'll post pics & review when they're on the 14.
FasterThanStink
posted June 20, 2007 05:35 PM
I can and do brake with one finger with the stockers. I see no reason for more power. (Trust me, I know). Most people with fading issues should try replacing the brake fluid first. At least once a year. Brake fluid is extremely hydroscopic and can really make a big difference with a fresh bleed and fill.
That's what gets you.
zx1kr
posted June 20, 2007 05:38 PM        Edited By: zx1kr on 20 Jun 2007 18:40
You're just not going fast enough! lol.... It's not just a braking improvement, although I'm always up for better brakes. I'm currently on a weight loss program. 2lbs would be nice to come off unsprung. Just for the record, I've not had the brakes fade on me. I'm not doin track days on this one.
posted June 20, 2007 07:15 PM
If I do anything to the brakes it'll be losing the squishing rubber tubing for steel lines.
zx1kr
posted June 20, 2007 07:34 PM
Done dat!
V2K_CCTX
posted June 26, 2007 05:30 AM
Concur on the steel lines, best change you can make for brakes. SWAP to syn brake fluid too!
0.25429511070251 seconds processing time
