BIKELAND > FORUMS > ZX-14.com > Thread: Modified my SMEG to sit lower......... NEW TOPIC NEW POLL POST REPLY
Brent Davis
posted June 06, 2007 05:56 PM        Edited By: Brent Davis on 6 Jun 2007 18:57
than it does in the regular stok location. My friend has a '07 with the SMEG from Muzzy and looks mean. I basically took the mid pipe, cut it and modified it to give me the same angle that the Muzzy pipe has. I made it to where it sits just like the Muzzy muffler.
Oh well, just showing what I did.
Black '06 ZX-14
jdzx14
posted June 06, 2007 06:18 PM
I personally think its badass lookin, good job. That paint is wet lookin!! i like the fox in the back, I guess I am not the only one with a mustang and a 14!
2007 Black ZX-14
kspz3
posted June 06, 2007 06:57 PM
Can you give a close up of the mounting? Any thoughts on performance?
KSP
posted June 06, 2007 07:02 PM
Hey Brock, you see that???
Good idea huh???...I think it's Perfect for DragRacing !!!
Brent Davis
posted June 06, 2007 07:11 PM        Edited By: Brent Davis on 6 Jun 2007 20:12
Thanks man. I've had Mustangs for a long time. The '88 coupe you see has made 1177 RWHP and 1097 RWTQ with 32 psi of boost and has been 170 MPH in the 1/4.
Brock definately is the man and has a great pipe kit that is produced. I just saw how the pipe can look with the lower look and liked what I saw. As for performance, I can't see where it definately would hurt anything at all. I used the same mid-pipe section that Brock supplies except I cut it and used that slight 45 degree angle. It is still a straight shot to the muffler. Sounds the same and runs the same as far as I can tell. I'll get a few more pics tomorrow of the mounting point. I used the same tab on the muffler and made a bracket that extends from the bottom all the way over to the lower mounting point of where the stock pipe used to bolt to. Real simple and easy to do.
BTW, I took off the passenger foot peg mount too. Cleaner look that way.
Black '06 ZX-14
trbobusa
posted June 06, 2007 08:18 PM
who cut your seat?
damn you must be fast! cause you were haulin ass when i passed you!!
posted June 06, 2007 08:24 PM
Brents bike has always bin one of the nicest IMO.
yes, who did the seat?
posted June 06, 2007 08:33 PM
the mustang in the back looks quick too
gms118
posted June 06, 2007 08:39 PM
That pipe does look good. Its got me thinking about cutting mine??? And who did your seat?
  Ignore this member    Click here to send gms118 an AIM message.
flyboy
posted June 06, 2007 09:13 PM
Looks great. More aerodynamic--
"The World's Fastest Indian"
One fast red ZX-14,
Brent Davis
posted June 07, 2007 02:20 AM
I did my own seat. I peeled off the stock cheap cover, took a marker and drew out the line of how I wanted the seat to be cut out and took my time with a razor and cut it out. I kept about 1/4" of the top foam since it is factory smooth and then glued it back to the bottom seat frame, I then added foam back in where I purchased from a upholstery shop and then just had them stretch and install the cover since they have the staples that are needed. It was kinda a pain but easy too. I will attempt to anything that I think I can do first before spending money and not be happy with the end result. I've seen plenty of seats that guys have had done and they are definately not up to my liking so that is why I did my own..........MY WAY.
Nelson Taylor
posted June 07, 2007 09:35 AM
I like it Brent.
Would you do another one?
Best #'s
1.54
4.03
6.02 @ 121mph
(Stock Wheelbase) 2006 ZX14
Brent Davis
posted June 07, 2007 05:31 PM
I like it Brent.
Nelson I'd love to man but I rather do stuff like this to "THE BIKE" that I am working on.
Here's a pic of the bracket that I made to hold the SMEG and with the pipe installed, you virtually can't see the bracket at all.
Black '06 ZX-14
kspz3
posted June 07, 2007 06:28 PM        Edited By: kspz3 on 7 Jun 2007 19:29
How sturdy is that mount? I need the pipe moved to get adequate tuck - now my heel goes to the side of the exhaust when I get on my toes on the peg...... hurting the aerodynamics - knowing that I am shooting for 200...... is the pipe mounted SOLID?
Thanks,
Kevin
BlackMagic14
posted June 07, 2007 09:17 PM
Did it affect cornering clearance It looks great Brent I might have to try that?
tonytooth
That looks great Brent!
MySpace
  Ignore this member    Click here to visit tonytooth's homepage.
Brent Davis
posted June 08, 2007 03:57 AM
Thanks,
Kevin
Man look at the new bracket that I made. It is solid and bolts to the stock mount where the stock exhaust used to bolt to, bolts to the lower frame where that plastic cover goes and then bolts to the pipe. YES it is very sturdy. Yes it gives a tad but not anymore than how it originally came from Brock.
Blackmagic I almost dropped the bike laying it over to check ground clearance and it is just fine. Like I said, I basically copied just like what Muzzy did to their SMEG. I put my stuff in the same location as they did so I can't go wrong.
Thanks fellas.
BlackMagic14
posted June 08, 2007 03:57 PM
Ok thanks Brent I wonder if it would damage the ceramic coating if I cut the mid pipe??? you know what I mean will it cause it to crack
Brent Davis
posted June 08, 2007 04:36 PM
I cut my mid pipe and it didn't hurt it at all. I priced out a new mid pipe from Brock's and they sell them for $170 if you muck up and wanna put the pipe back in the regular location. Of course I knew that I wasn't going to muck up though.
Black '06 ZX-14
johnsonzx14
posted June 10, 2007 02:41 PM
looks great dude, I might do that in the future
MADDOGC5
posted June 10, 2007 04:48 PM
SWEEEEEEET LOOKING BIKE.... that nice bro
icetee
posted June 14, 2007 06:27 AM
pic's didn't show up
dac
posted June 19, 2007 02:32 AM
Hey Brent.... thats looks great...ive been hesitating order the s-meg...because frankly i dont love the look...but what youve done makes a huge difference in appearence..to me anyway... let me ask ya... do you think youll notice any difference in performance?...from a negative standpoint....also...ya think you need to re-map? Thanks Brent.... your whole bike is really set up nice...just the right blend
  Ignore this member    Click here to send DAC an AIM message.
ZXLNT
posted June 19, 2007 04:24 AM
That looks much better than the stock setup. I like megaphone exhausts but not with a big upsweep. That looks more natural and kind of like a sidewinder. Nice Job..
nightmare
ACP Racing
posted June 19, 2007 04:43 AM
yeah I have to admit it. That is some really nice work man!
2006 ZX14 Ninja "SWINE FLU"
60ft 1.23
8th Mile 5.16
ACP Racing
0.28347992897034 seconds processing time
