BIKELAND > FORUMS > ZX-14.com > Thread: speedohealer NEW TOPIC NEW POLL POST REPLY
ouijonbu
Ride with pride
posted June 05, 2007 02:49 PM
speedohealer
14ners
If i get a pcIII do i still need a speedohealer, and a tre
chez
posted June 05, 2007 03:17 PM
Not for PC111 only if you change the gear ratios
Chez
  Ignore this member    Click here to send Chez an AIM message.
lietoome
posted June 05, 2007 07:45 PM        Edited By: lietoome on 5 Jun 2007 20:46
PC3=fuel mapping
speedohealer= bypass speed limiter & correct the speedometer.
TRE= opens secondary throttle plates(flies) sooner and loses the gear indicator.
to answer your question= No.
ouijonbu..in Korea?
ouijonbu
Ride with pride
posted June 06, 2007 01:33 PM
thanx bros.,
Yes in korea 4 times, all at camp kyle or red cloud
posted June 06, 2007 04:45 PM        Edited By: bigdtd on 6 Jun 2007 17:46
read brocks diaries, you don't ever need a tre. removing the secondary butterflies will pick up your low end without messing up your gear indicator like a tre would.
the power commander (pclll) allows you to remap the fuel in case you put a pipe on it or pull the butterflies or want to tune it better when you make changes..
the speedo healer allows you to recalibrate your speedometer so if you changed gearing or tires you could make it read accurately. it also allows you to set the speedo low so you can exceed the 186 mph limiter built in by the factory.
0.43851184844971 seconds processing time
