BIKELAND > FORUMS > ZX-14.com > Thread: Getting to the air cleaner? NEW TOPIC NEW POLL POST REPLY
kspz3
posted May 14, 2007 06:54 AM
Can anyone tell me what needs to be done to get to the aircleaner. I made an unsuccessful first attempt - and could use some input - also - how long would it take to replace the aircleaner start to finish?
KSP
ninjaboy311
posted May 14, 2007 07:57 AM
Remove the ram air covers, the fins, and the plastic gas tank shell.
Filter is in the left side frame under the screwed in cover. Take the cover off, pull the filter out, install new filter. Bolt plastics back up.
All of 15 minutes tops.
Ojref
posted May 14, 2007 08:01 AM
1. Remove the end bolts from the ram-air duct covers
2. Remove the bolt from the tank shroud
3 Remove bolts from the side grille(s), they are fastened with protrusion studs/grommets and pop off
4. Pop off and remove tank shroud
5. Pull back rubber cover from the left side near the steering head. You will see a plastic retangular cover with 2 bolts. Remove those and the panel-filter slides out.
2006 Kawasaki ZX-14 Ninja, Red now with mo' Brock's in my lyfe
1991 Yamaha Vmax - Because I need a mule to carry the manhood
2002 Ford Lightning - Ford GT Aluminum block engined, 802HP 911TQ now WhippleCharged
kspz3
posted May 14, 2007 09:13 AM
Questions
1. Will I need to remove the Ram Air Duct cover or just the end bolts?
1.a I am assuming this is the nose piece with the big hole in it for the ram air - - do I need to remove mirrors or windshield.
2. Tank Shroud - I see three bolts - including the one through my steering damper - are there any others ?
3. - I konw how to get that off.....
4. I believe this tank shroud is the piece in front of the tank.... that has the top of it scooped out to place your chin when in a tuck. - is that correct?
5. I understand this part.....
Thanks,
KSP
0.39963316917419 seconds processing time
