BIKELAND > FORUMS > ZX-14.com > Thread: Has this been done?? NEW TOPIC NEW POLL POST REPLY
BarBender
posted April 30, 2007 01:40 AM
Was just fiddling around with a photograph of a black 14 and was wondering if anyone has had undertail pipes fitted?
jdzx14
posted April 30, 2007 02:37 AM
I dont know but I like!! I used to hate undertail exhaust but after I owned one I loved it, it made every thing look less crowded and usually easier to work on!
2007 Black ZX-14
blackbullet76
posted April 30, 2007 03:06 AM
Man! That would be clean lookin! It might be a little restrictive on the 14 though, but It would look good.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
phytrax
posted April 30, 2007 03:39 AM
Doesn't seem like there's enough clearance to me, but I always liked the undertail exhausts.
KX450F - kickstand
>>> MySpace --CLICK-- <<<
jeepersracing
posted April 30, 2007 03:56 AM
it can be done i have made one for my 900rr
  Ignore this member    Click here to visit jeepersracing's homepage.
posted April 30, 2007 05:14 AM
your 900rr is alot different than a 14!
There is not enough clearance betewwn the fender and tire!.
Even if you cut the inner fender, you have to relocate all the electrics, your passenger would not like you, and then the 1.5 lb bottle of dope won't fit under the hump....
Undertails are purely cosmetic, all those tight unnecessary bends in the exhaust do NOTHING for HP.
To each his own.... Good luck.
ninja14
posted April 30, 2007 10:20 PM
Sure they do...........the reduce it a good bit at high RPMs :-)
I'm glad that now I can ride w/o any pipes and it's still quiter than some full exhaust kits out there.....using a special "radial muffler" did the trick.....
NinjaNick
'08 ZX14 (Blue)
posted April 30, 2007 10:28 PM
+1
BarBender
posted May 15, 2007 12:49 AM        Edited By: BarBender on 15 May 2007 01:52
Twin Undertail Pipes Prototype
Ok Folks,
Well I had a crack at it.
A friend fabricated twin undertail pipes for my 14. I'm testing it out at the moment. Have done 600klm with them over the last 3 days.
Sounds the bizzo - but still need to sort out some clearance issues when riding two up. That may require some further bending.
After that we'll probably make the cans a little longer and then wrap them in carbon fibre.
Hopefully we should sort it all out in the next couple of weeks and then it'll be off to the dyno.
This was taken last Friday. Have since fabricated the link pipe and the pipe going over the swingarm to allow for more clearance.
After the weekend and 200ks with a pillion we found that there wasnt enough clearance between the pipe and tyre in the area around the rear shock. So will need to re-fab the pipe in this area. The catch 22 here is obviously having a pipe with too many bends.
The pipe sounds great. About as loud as a Muzzy M10 but alot deeper. We built in a heatshield in the wheel well which worked a treat.
Will possibly make the pipes a little bigger in diameter and then weld some rings on the end to finish them off.
kawpower
Mr kawasaki 2 you!
posted May 15, 2007 03:38 AM
How about spacing them out like the zx10 for clearence.
blackbullet76
posted May 15, 2007 03:50 AM
Mabye make it like the MV Augusta, flat and wide piping.
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
icetee
posted May 15, 2007 06:14 AM
I think it looks pretty kool, did you think about trying to relocate the tag so that the pipe will be the only thing there.
raband
posted May 15, 2007 06:25 AM
Hell yeah - that'd work well - even a surround for the pipes in mesh or hole punch that flow with the bike and blend the pipes in.
F_Sik
posted May 15, 2007 07:31 AM
cool as hell
As long as y'all don't have any kryptonite/I'm gonna be alright.
  Ignore this member    Click here to send F_Sik an AIM message.
posted May 17, 2007 03:49 PM
hellacious effort, you got skills, still love the old four into one megaphones, but this looks gp
BarBender
posted May 18, 2007 04:02 AM        Edited By: BarBender on 18 May 2007 05:04
Thanks guys.
Have thought about the MV style of making them oval and wider. Decided to go for the above given that it would be a little easier. Cant move the tag. By law Im required to have it where it is. Dont worry it'll come off for the track days.
Carbon graphite on the cans in the next week or so.
0.47473907470703 seconds processing time
