BIKELAND > FORUMS > ZX-14.com > Thread: 8.91 RUN ZX14 NEW TOPIC NEW POLL POST REPLY
RICH CRAFT 1
posted April 25, 2007 07:08 AM
8.91 RUN ZX14
http://videos.streetfire.net/search/zx14/0/379730d0-ab26-4a11-b808-98fd00c37528.htm
Halvefast
posted April 25, 2007 07:36 AM
Assist:
[url=http://videos.streetfire.net/video/379730d0-ab26-4a11-b808-98fd00c37528.htm][/url]Click here to see Video
Nice job! They say smooth is the way to go fast.
ECTA Ohio Mile 195.132mph
shawnski
posted April 25, 2007 07:49 AM        Edited By: shawnski on 25 Apr 2007 08:51
nice run rich , what size sprockets you are having ? the rear looks pretty big!!
where do u located in texas? what track is that?
smokinzx14
posted April 25, 2007 10:04 AM        Edited By: smokinzx14 on 25 Apr 2007 11:06
Nice pass ...Thanks for the video ...... and Another member of the 8 second club ...
icetee
Very strong pass!! The view from the rear never changes, unless your in the front
blue max
posted April 25, 2007 11:01 AM
thanks for the great video, not only sounds cool but, i can really concentrate on the motor when launching! i know after watching this over and over that i think i am not pinning the throttle soon enough to keep the motor up. i have the rpm up when staged then let the clutch out, but i let the motor bog to much. i can't wait till friday night! also i am not warming the shinko up enough, if i did leave like that it would of really spun.
best 9.23
Halvefast
posted April 25, 2007 11:40 AM
I just noticed that myself, watched it again, he is going thru all 6 gears!
You can here the chain rub the swingarm guard all the way down the track.
That is Texas Motorplex in Ennis outside Dallas.
blue max
posted April 25, 2007 12:10 PM
i am 16/43, i also use alot of gears, but, not sure if i get sixth as you see i barely get mine stopped. no nose dive with it strapped so not sure how much front brake pressure to use yet
best 9.23
ZXLNT
posted April 25, 2007 12:17 PM
Man it sounds to me like your launching just fine, a little bit rpm decrease but looks and sounds good. You could really hear the tire screech the rubber on the 1/2 and 2/3 shift on the 2nd pass. I dont think thats the chain guard rubbing as much as it is just chain or tire noise.....
Bently
2012 14r In Blue and no Mods!
posted April 25, 2007 12:32 PM
I get into fourth just at the finish line, I would think you would want to be geared so you shift less then all the way to 6th. Seems the more shifts your making the more time you lose?
blue max
posted April 25, 2007 01:38 PM
that is a good thought bently, when i get my s--- together i will swap spockets at the strip, but boy is it fun right now. i am 185 suited and smokin doesn't seem i need that kind of gearing either
best 9.23
kawasaki_rick
posted April 25, 2007 02:19 PM
Im just went from 16\41 to 16\43. Best pass is 9.30 \151 with 16\41. we will see friday if it works out. Lost a little wheelbase. Ill let ya know.
posted April 25, 2007 04:47 PM
Very Nice passes!!!
nightmare
ACP Racing
posted April 25, 2007 08:06 PM
now that's leaving. Nice pass!
2006 ZX14 Ninja "SWINE FLU"
60ft 1.23
8th Mile 5.16
ACP Racing
RICH CRAFT 1
posted April 26, 2007 07:14 AM        Edited By: RICH CRAFT 1 on 26 Apr 2007 08:37
Quote i am not warming the shinko up enough. Blue Max 8 Pounds of air. Gears 16-48 or 19-48. 190pound rider. best 1/4mi 8.89 @152.38. best 1/8mi 5.660 @125.14.best 60ft 1.391
smokinzx14
posted April 26, 2007 08:11 AM
8 pounds?? Damn your track must suck for hook ...I run 23 psi in my shinko most days...If the track is bad i drop as low 17 psi...
I'm just ordered a 42 rear and i'm going to give that a shot next week ..Right now i'm 16/41 and i feel it needs just a tad more gear.... I'm stuck with 1.38 to 1.40 60 footers but i feel with just a bit more gear maybe i could get 1.35 to 1.36 60s ...Like most of my plans it mostlikey will not work but it's worth a try ... Smokin...
iflyems
posted April 26, 2007 09:19 AM
You dont need more gearing. Just rev the engine more and dump the clutch quicker you big sissy
blue max
posted April 26, 2007 09:33 AM
that is my plans now that is longer
best 9.23
burnout
posted April 27, 2007 06:32 AM        Edited By: burnout on 27 Apr 2007 07:37
I think going up one in the back is a good idea. I have to shift into 5th right before the traps with 16/41. I'd rather be at the top of 5th if I have to make the shift anyways.
1/8 5.66@129.77
1/4 8.74@159.60
blue max
posted April 27, 2007 06:58 AM
i have watched this video so many times that i will probably be the wheely king tonite!
best 9.23
burnout
posted April 27, 2007 08:05 AM
Be safe, I busted out my pan and oiled down my rear tire a few weeks back at the strip. It was like being in the ice capades.
1/8 5.66@129.77
1/4 8.74@159.60
blue max
posted May 25, 2007 08:22 AM
thanks again richcraft! headed to the strip tonite and had to get pumped up
best 9.23
Hawkman
posted May 25, 2007 09:02 PM
Why does it not suprise me to see another red 14 in the 8s?
posted May 26, 2007 03:02 AM
sweeeet!
gms118
posted June 06, 2007 01:49 PM
Hay what are you guys launching/ staging at?
  Ignore this member    Click here to send gms118 an AIM message.
0.29501104354858 seconds processing time
