BIKELAND > FORUMS > ZX-14.com > Thread: speedo acting funny NEW TOPIC NEW POLL POST REPLY
jessejames82
posted April 20, 2007 05:42 PM
speedo acting funny
this just started yestarday after i got done at the track going home... my speedometer doesnt work most the time, only sometimes at low speeds it flickers doesnt stay on how fast i am going, it just goes to it then back to zero also my odometer wont regester but at low speeds. my rpms and fuel gauge are fine but everything else i dont know
Tool man
posted April 20, 2007 06:31 PM
Do you have a Speedo Healer attached ? If not seems like a warranty issue.
The banks are failing..
The banks are failing...
Invest in Ammo
ninjavin
posted April 20, 2007 07:01 PM
Before going to the stealership and let the butchers at it, pull the sprocket cover off and check for a build-up of grease on the pickup and the sprocket nut from the chain. Should only take you about 10mins. to check.
ninja
posted April 20, 2007 09:09 PM
Sounds like what happened to my 2000 zx9, dealer replaced speedo, didn't solve problem. Ended up having to replace wiring harness under warrenty.
wrongway
posted April 20, 2007 09:58 PM
change the front sprocket ?
the square part is what the sensor pics up on. If you used that to remove the nut, you may have bent it . If you ran it that way you may have screwed up the sensor,
Roy
0.22801899909973 seconds processing time
