BIKELAND > FORUMS > ZX-14.com > Thread: 14 front axle attachment NEW TOPIC NEW POLL POST REPLY
elrwfo
posted April 17, 2007 05:56 PM
OK, my oem tool kit doesn't come with a'tool to loosen the front axle. Any tips to get it loose??
zerMATT
posted April 17, 2007 06:11 PM
Sucks doesn't it? I can't understand why Kawi doesn't include a tool capable of removing the front axle... that's completely unacceptable as it's not a "common" tool that you might already have kicking around the garage.
I ended up purchasing a "Motrax Axle Wrench" from Cycle Gear for $16.00.
http://www.cyclegear.com/spgm.cfm?L1=&L2=&L3=&L4=&item=MRX_TOOL&tier2=14
elrwfo
posted April 17, 2007 06:37 PM
My zrx had a factory tool, same type axle and it twisted bent and broke without breaking the nut loose, maybe that is why??
zerMATT
posted April 17, 2007 06:48 PM
Same here - I used the factory 'tool" on my ZRX and twisted it all to hell. Kawi needs to learn how to make an inexpensive tool that can be included in the tool kit, or simply make the front axle accept a 17mm hex wrench like the ZZX1200 did... I've got 17mm hex wrenches already, and they can be picked up at almost any tool supplier (like Sears) 'cause old aircooled VW's have needed that size forever...
ZXLNT
posted April 17, 2007 08:00 PM
My mechanic friend had a tool similar to the one shown above. It lasted about two times before it cracked into pieces. Too thin of aluminum wall.. Perhaps that cycle gear one is better though...
Ojref
posted April 17, 2007 08:56 PM
+1
Purchased and put in the underseat tool bag.
2006 Kawasaki ZX-14 Ninja, Red now with mo' Brock's in my lyfe
1991 Yamaha Vmax - Because I need a mule to carry the manhood
2002 Ford Lightning - Ford GT Aluminum block engined, 802HP 911TQ now WhippleCharged
MasterBlaster
posted April 18, 2007 04:16 AM
Get a sparkplug socket with the hex top. It fits perfect and just stick the extension in from the opposite end. Works like a charm and only a couple of bux.......TB
Xtremespeed
posted April 18, 2007 03:13 PM
Exactly what I was going to say.
zerMATT
posted April 18, 2007 04:09 PM
No, this one is quite good. It's a solid chunk of steel, so I don't think it's gonna bust into pieces. It's a bit heavy, but it's under the seat in the tool kit now.
Nixter
posted April 18, 2007 04:15 PM
I bought a large bolt from Home Depot with a head that fit. Put 2 nuts on locked down together with a little epoxy of the threads......instand $2 indestructable axle tool!
2012 ZX14R - Black
chez
posted April 18, 2007 04:28 PM
But if you leave the hex end of the axle clamped and just undo the other end you don't need any tool....
Chez
  Ignore this member    Click here to send Chez an AIM message.
zerMATT
posted April 18, 2007 04:44 PM
Well, actually... you do need a tool to undo the "other end".
Of course you'd leave one end clamped, but you still need something to turn the axle on the unclamped side.
elrwfo
posted April 18, 2007 05:24 PM
BINGO, spark plug backwards, I know there was a trick!!!!!!!! THANKS
0.25980615615845 seconds processing time
