BIKELAND > FORUMS > ZX-14.com > Thread: the 14 in warm weather NEW TOPIC NEW POLL POST REPLY
blackbullet76
posted April 12, 2007 05:08 AM
Since hotter days are coming, I was wondering how hot the 14 runs during 90+ degree days? I guess this question is targeted towards the 06 14 owners that rode during the summer months last year. Thanks.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
ZXLNT
posted April 12, 2007 05:55 AM
Mine never overheated. I appears that it runs warm, but not soo much to overheat and puke antifreeze nor flash the overheat warning.
raptor14
posted April 12, 2007 07:08 AM
1. Mine never overheated. Overheating only occurs if the indicatoris blinking at you. It never did that.
2. Most of the time when moving over 40 mph the temp indicator ran at the mid-mark on 90+ deg F days. Under 40 mph it ran one mark above the middle. Only once did it ever go to the top mark. It was 100 degrees outside, I had been pushing the bike real hard, rounded a corner to find road work up ahead and all traffic at a dead stop. Five minutes at idle and the temp gauge reached the top mark. I just shut the engine off as I didn't know how long I was going to be stuck. About a minute later I turned the engine back on and all was fine.
3. About mid-summer I added about 1/2 a bottle of Water Wetter. It didn't really effect the cruise temps at all. Same indicator marks for going less than and more than 40 mph. What it did effect was the rate at which the system heated up and cooled down. It heated up slower so I could sit at a red light longer without it reaching one mark above center and it cooled down very quickly.
4. This summer I'm trying Engine Ice coolant (propylene glycol rather than ethylene glycol) and I added about 1/2 bottle of Water Wetter. It got cold on me again up in the northeast so I haven't had a chance to try it out yet.
5. Although I hear the 07's don't run as hot what I really believe is that the 07 temp calibration has been changed, not the cooliing system. Kawasaki reps have told me a couple of times that the 06 temp gauge reads a hot spot rather than the average value and that the calibration needed to be updated. Don't know this for a fact but a calibration has no cost associated with it and the production hardware stays the same between 06 and 07.
blackbullet76
posted April 12, 2007 07:16 AM
Wow, that's alot of info! Thanks
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
posted April 12, 2007 11:33 AM
"4. This summer I'm trying Engine Ice coolant (propylene glycol rather than ethylene glycol) and I added about 1/2 bottle of Water Wetter. It got cold on me again up in the northeast so I haven't had a chance to try it out yet."
+1
Thats the most popular product in south FL. My ZX14 didn't have probs before I dumped it in last summer though.
raptor14
posted April 12, 2007 03:03 PM
Yeah stevewfl, you da one who made me decide to give Engine Ice a try. Actually I'm cheating since Water Wetter is compatible with Engine Ice so I guess its a seat of the pants test of regular antifreeze and Engine Ice, both with Water Wetter. It's gotta clear up here someday. I just installed a TechMount and Garmin Zumo 550 as well as changed the coolant, so I'm going nuts not being able to ride.
zxbob
posted April 12, 2007 03:37 PM        Edited By: zxbob on 12 Apr 2007 16:38
see:
http://www.bikeland.org/board/viewthread.php?FID=27&TID=30603&set_time=
Bob
Tool man
posted April 12, 2007 05:42 PM
Mine never overheated..I live in Phoenix Az. right next door to hell. Nuff said...
The banks are failing..
The banks are failing...
Invest in Ammo
raband
posted April 12, 2007 06:14 PM
07 zx14
Have been out on over 40C days (over 104F)
Bike is showing full on the guage and the heat coming from the engine onto the knees can be pretty uncomfortable but theres never been any sogn of overheating or issues due to heat.
I think the guage topping out pretty early and the engine being right next to the plastic by the knees with the frame going over the engine instead of around combines to make the issue seem worse than it is.
PS - its black - its f'kn sexy and it pulls better than a dentist
Ojref
posted April 12, 2007 06:32 PM
85% H20, 15% glycol and Water Wetter allows the bike to dump off heat much quicker than the 50/50 mix. I've done this for every bike I've ever owned - You think the 14's bad about heat - try riding a 2001 R-1 with 50/50. That bike would routinely get up to 251 at a redlight here in Houston.
2006 Kawasaki ZX-14 Ninja, Red now with mo' Brock's in my lyfe
1991 Yamaha Vmax - Because I need a mule to carry the manhood
2002 Ford Lightning - Ford GT Aluminum block engined, 802HP 911TQ now WhippleCharged
fastestbusaaround
I eat Fish...
posted April 12, 2007 06:56 PM
I use Redline water wetter. Never went past 1 bar below the end at any temps or speeds; even at idle for extended periods, but the heat on the rider can get warm. It's much better with a full system than with the original cans and PC3 mapping has a marked effect on the engine heat...richer mixtures make a huge difference on the heat output. When you lean it out, you see the heat rise much quicker, both on the gauge and on heat coming up from the front. 95% of the time, it would run at the halfway mark or less. My R1 is 100 times worse. That's one thing the Busa has over the 14...no heat issues at all.
FYYFF!!!
nabrxx
posted April 12, 2007 08:59 PM
Mine never overheated and Ive done some 90+ degree days in manhattan traffic. I would not say the bike runs cool though, my 98 blackbird ran cooler.
What we don't understand, we can
make mean anything... src="http://www.bikeland.org/board/i
mages/smilies/smile.gif" border=0>
raband
posted April 12, 2007 09:51 PM
Definately. The Blackbird also seemed to lose ambient heat as soon as it was moving - the 14 seems to bring it with it (still heat coming from the knees area while cruising - the XX was cool once moving)
blackbullet76
posted April 13, 2007 03:06 AM
Well, I did a mod to my 14 yesterday that I done to my 01 zx6r when I had it. I installed a bypass switch so I can turn on the fan anytime I want. I did this on my zx6r when I would be in stop and go traffic and it would pretty much hold the temp it was at before I turned it on. I hope it does just as good for the 14. We'll see soon enough.
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
fastestbusaaround
I eat Fish...
posted April 13, 2007 05:51 AM
Thats cuz the 14 was designed to ride in winter too...I hear they are coming out with Pilot Snows just for the 14.
FYYFF!!!
raband
posted April 13, 2007 07:39 AM
Queue Homer: Mr Plow
fastestbusaaround
I eat Fish...
posted April 13, 2007 08:19 AM
Yup, I hear they're coming with that option too, in 08.
FYYFF!!!
posted April 13, 2007 09:35 AM
See, Michelin PPs work best in snow too. Wish I'd have had them back when I lived around the GAP.
Maybe they'll work in Florida sand too, cuz PPs are the BEST
zxbob
posted April 13, 2007 02:04 PM
Yer kill'in me ....... L.O.L.
Bob
fastestbusaaround
I eat Fish...
posted April 13, 2007 09:50 PM
Shoes and white sox Steve? No boots?
FYYFF!!!
zxbob
posted April 14, 2007 03:16 AM
Poser ....
Bob
blackbullet76
posted April 14, 2007 04:13 AM
And he doesn't havea helmet on either!!! What tha hell?
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
0.367516040802 seconds processing time
