BIKELAND > FORUMS > ZX-14.com > Thread: Chain adjustment... NEW TOPIC NEW POLL POST REPLY
Squareman357
posted March 26, 2007 05:12 AM
Chain adjustment...
I did a couple of searches, and while I found plenty of threads about what chain to get to replace the stocker, I couldn't find what I was looking for, so I'm posting up.
Ok, I've never had a rear set up like this. On all of my previous bikes, there was an adjuster bolt you could turn out or turn in to adjust the slack in the chain WITHOUT having to loosen the axle bolt. According to the manual I have remove the cotter pin and loosen the axle BEFORE I can take up chain slack. Anyone done it a different way? Do I absolutely have to loosen the axle?
Keep the shiny side up!
Square
'06 Ebony Metallic ZX-14 - "Delilah"
'02 Silver CBR1100XX - "Stormcloud"
'04 GS500F - "Wife's Bike"
  Ignore this member    Click here to send Squareman357 an AIM message.
Tool man
posted March 26, 2007 06:59 AM
Yes you do have to loosen the axle. Before you turn the 12 mm axle / chain adjustment bolts.
The banks are failing..
The banks are failing...
Invest in Ammo
blackbullet76
posted March 26, 2007 09:11 AM
Yeah, there's little notches the axles blocks (whatever you call them). Get those to match up with the notches on the swingarm on both sides. That puts your rear tire inline with the front, supposedly. That's what I go by. I've adjusted mine twice so far, I've got 2000 miles on it.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
ninja14
posted March 26, 2007 11:24 AM
Simply pull the rear axle back until the proper tension is reached and the chain is straight from sprocket to sprocket - forget those notches.....
Xtremespeed
posted March 26, 2007 03:37 PM
Those notches are not usually aligned correctly. Not sure why. I usually put a wrench on both sides at the same time and turn the bolt even amounts until I have the chain slack correct.
When in doubt, Flick it!
0.28904914855957 seconds processing time
