BIKELAND > FORUMS > ZX-14.com > Thread: How in the hell? NEW TOPIC NEW POLL POST REPLY
1bigkaw
posted March 11, 2007 10:24 AM
How in the hell?
How in the hell do you get the transmission bolt out of this son of a bitch? I can't get the bastard out. Anyone taken theirs out yet?
Tool man
posted March 11, 2007 12:14 PM
Are you asking about the counter shaft nut, that holds the the counter shaft sprocket on ??
Otherwise I do not know what the Hell you are asking?
The banks are failing..
The banks are failing...
Invest in Ammo
blackbullet76
posted March 11, 2007 12:16 PM
got a pic?
zxbob
posted March 11, 2007 01:06 PM
You know ......................... "the transmission bolt"
Bob
twista
" Get up, and Stay up ! "
posted March 11, 2007 04:53 PM
yea U know!!
Xtremespeed
posted March 11, 2007 04:54 PM
Transmission bolt! Duh!
When in doubt, Flick it!
1bigkaw
posted March 11, 2007 04:56 PM
I was told that it is called the transmission bolt. Right side just above the oil fill/dip stick. It uses a 8mm. It's hollow all the way through to the other side. Sorry not good at putting pictures up. And I'm ordering a manual this week but want to get this done. Anyone had this out and how?
Bobs07zx14Black
posted March 11, 2007 05:12 PM
Why do you want it out anyways?
Bob
Bob
1bigkaw
posted March 11, 2007 05:41 PM
I need to take it out to install race railz (a type of frame sliders)
1bigkaw
posted March 12, 2007 04:55 AM
Nobody knows?
posted March 12, 2007 05:42 AM
If its the large bolt at the back of the cases, and the one I'm thinking of, it goes through the swingarm and frame too, you have to unload the rear suspension, and drive it out with an extension.
1bigkaw
posted March 12, 2007 04:19 PM
Actually it is just above and to the right of the bolt that goes through the swingarm. It is the one that is just above dip stick. Thanks for the help. It is a tough crowd at this sight. And I did order a manual for the bike this morning but I would like to get the bike back together before this weekend.
smokinzx14
posted March 12, 2007 04:58 PM        Edited By: smokinzx14 on 12 Mar 2007 18:11
1bigkaw I don't think the guys ment be hard on you ..When i read it i could not understand what bolt you were talking about so i didn't answer your post ... I parted out an 06 zx14 and took that bolt out with no problems ..I did it so fast i don't remember what i used to remove it ..Hell i took the hole bike apart in an hour... I beleave i used a punch to remove the locking nut and then used an allen wrench to back off the spacer that loads the spacer between the case and the frame and then slid the bolt right out .. That my have been for the swing arm bolt but the motor bolt has them same spacer that screws into the cases between the frame and cases... Smokin...
nightmare
ACP Racing
posted March 12, 2007 05:58 PM
Sounds like those rails are tearing you a new ass there killer
2006 ZX14 Ninja "SWINE FLU"
60ft 1.23
8th Mile 5.16
ACP Racing
posted March 12, 2007 08:12 PM
a bolt is hollow? naw, tell me it ain't so!?
posted March 12, 2007 08:13 PM
when you get it worked out will you please post pics? thanks man
14black
posted March 13, 2007 07:56 AM        Edited By: 14black on 13 Mar 2007 08:57
Maybe this'll help clarify what the hell the "transmission bolt" is...I assume you're referring to one of the three in the pic below???????????
aliveagain
posted March 13, 2007 08:07 AM
I thought he was talking about the upper trans mount.Nut is on other side on a 12,assuming it's the same.
blackbullet76
posted March 13, 2007 09:47 AM
If he's having trouble getting any bolt loose, I'd say it's from the loctite that kawasaki uses quite generously. I had a hell of a time getting the motor mount bolts loose to install my frame sliders. So I don't confuse anyone, this bolt is in front of the foreman grills
1bigkaw
posted March 14, 2007 07:22 AM
I wish I was better at this whole computer thing and also with the wrenches. The bolt is to the left side of this picture, it uses an 8mm alan. It is hollow and silver just above and a little to the left of the dipstick. I have continued to try to get it off different ways; heat (for the loctite), puching it through (but not hard) from the other side (as one mech. told me to), and like I said before even broke a 8mm off on it. I continue to find pictures on their site of a 14 and other Kaw's and it is installed there. So I have the right bolt but what the hell? The boys who sell these and make them said they installed them on Ricky Gadson's bike in 20 minutes! I'm going to be pushing 20 days soon. I really like the whole idea behind them (the idea that they will be better than normal sliders) or I would send them back. So I'm still trying.
aliveagain
posted March 14, 2007 07:46 AM
On the 12,there is another piece directly on the other side that tightens up the mount when you turn it counter-clockwise.It will never loosen up that way.Go to the other side of the bike above the shifter and loosen that nut.It will probably be a 15 or 17mm socket.
1bigkaw
posted March 14, 2007 08:20 AM
I've loosened the nut on the other side and still nothing. Thanks, any help is appreciated.
blackbullet76
posted March 14, 2007 08:41 AM
This is just an idea, but is it left handed threads maybe?
1bigkaw
posted March 14, 2007 08:56 AM
Won't budge that way either. This whole thing (getting this bolt out and installing these) seems so fu.... simple. What the fuck? I should be getting the manual tommorrow but why can't I figure it out right now? I'll be on medication before these fu.....kers get installed.
14black
posted March 14, 2007 09:57 AM        Edited By: 14black on 14 Mar 2007 11:00
So it's #4 in the pic below??? If so, that's the rear motor mount bolt. Remove the nut from the other side and then MAKE SURE YOU HAVE THE CORRECT-SIZED ALLEN WRENCH...preferrably a long one to get extra torque on it, or just add an extender to get extra torque........or just buy the type I got from ebay: http://motors.search.ebay.com/_W0QQsassZsupplyQ28nQ29demand
Good luck...
0.29467415809631 seconds processing time
