BIKELAND > FORUMS > ZX-14.com > Thread: Can you use coolant undiluted? NEW TOPIC NEW POLL POST REPLY
nabrxx
posted February 24, 2007 11:53 AM
Just bought some to top off the 14 and it gives specs on the back when cut 50% with water...do I have to go out and buy distilled water now or can I use it undiluted?
What we don't understand, we can
make mean anything... src="http://www.bikeland.org/board/i
mages/smilies/smile.gif" border=0>
Stalwart
posted February 24, 2007 12:14 PM
You can buy the pre-diluted variety or you can add water. I don't bother with distilled in my cars but in the bike, I prefer it. Straight antifreeze doesn't cool as well as 50/50 mix, so no, don't use it straight.
Stuart
Ridin' the Trump train.
nabrxx
posted February 24, 2007 01:21 PM
Thank you, I just got back from the drugstore with a QT.....Thanks again!!
Xtremespeed
posted February 24, 2007 07:23 PM
For every 1% glycol you add, you raise cylinder head temp approx 1 degree, so
50/50 would be 50 degrees hotter. You just need enough to lubricate the pump,
and keep from freezing. I only use about 2 cups. Just a FYI.
When in doubt, Flick it!
matt sterbator
Hiding in the bushes
posted February 25, 2007 12:51 AM
Unless it's gonna freeze, I've never used anything but about a 75/25 mix of distilled water and water wetter.
riaansh
posted February 25, 2007 09:59 AM
What stops the corrosion in engines. Isn't it antifreeze? If so, how much antifreeze do you need to stop this from happening. What is water wetter? I'm not sure we get it here in SA.
ninja14
posted February 25, 2007 10:28 AM
I put in a bottle of Engine Ice and the rest is dist water.
Pure water would be best, but the metals won't like it........
burnout
posted February 27, 2007 06:10 AM
Don't use it at all if you go to a drag strip, the stuff doesn't evaporate and needs to be burned off the track which is a monumental waste of time.
1/8 5.66@129.77
1/4 8.74@159.60
fastestbusaaround
I eat Fish...
posted February 27, 2007 03:20 PM
I use one bottle of redline and the rest is water...works fine for me and runs cool. The PC maps make a huge difference when you lean them out though...night and day.
FYYFF!!!
0.38883709907532 seconds processing time
