BIKELAND > FORUMS > ZX-14.com > Thread: Block off plates on vavle cover? NEW TOPIC NEW POLL POST REPLY
CajunBoyz
posted February 19, 2007 06:06 PM
If i install block-off plates on top the valve cover or just block-off the stock ones with No hose and eclectrical will this work ,What do i do with the solenoid thing where the wire connects??? if I leave the electrical connector to it un hooked will that be ok? It won't set a code or something???Just want to be sure, Thanks
kawabusakid
Fast as my $$ will take me
posted February 19, 2007 07:48 PM
i left mine still mounted in place w/o hoses,plugged in and installed my blockoffs..worked fine
  Ignore this member    Click here to visit KAWABUSAKID's homepage.
BlackMagic14
posted February 19, 2007 09:34 PM
What are the benefits of block off plates?
kawabusakid
posted February 20, 2007 05:08 AM
they work...reed valve chamber block off plates are designed to safely block the reed chambers after removal of the air suction valve system, for engines used in racing applications where stock emissions hardware is removed.
0.40266013145447 seconds processing time
