blackbullet76
posted January 28, 2007 09:59 AM
removing air filter screen
Does this help at all? The map I have installed is made for this, but I don't have it removed. I was also wondering if the screen helps hold the filter element from coming apart?
posted January 28, 2007 01:08 PM
quote: I was also wondering if the screen helps hold the filter element from coming apart?
one can only assume so.
kawabusakid
Fast as my $$ will take me
posted January 28, 2007 02:52 PM
Edited By: kawabusakid on 28 Jan 2007 14:54
if you take the screen out,it will not affect your paper filter or strength of surrounding case......."what so ever",done this my 02 R1,ZX-12,& 14 ...it's your call,it will pull harder once your air box starts to pressurize,w/less restriction.....
Ojref
posted January 28, 2007 05:21 PM
The filter will maintain its integrity with the screen out. It's primary function is a flow regulator and a deresonator. The problem is, your bike might run lean as hell without it and you will lose power unless you dyno and remap.
2006 Kawasaki ZX-14 Ninja, Red now with mo' Brock's in my lyfe
1991 Yamaha Vmax - Because I need a mule to carry the manhood
2002 Ford Lightning - Ford GT Aluminum block engined, 802HP 911TQ now WhippleCharged
posted January 28, 2007 05:24 PM
I jerked the screen off of my track bike filter, just because it was there and I was there. If i happen to be near that location with the 14, it'll be gone from that bike too.
blackbullet76
posted January 28, 2007 05:34 PM
Wel, like I said the map I have is for the screen removed so I'm good to go in that department. So if it will give more umph, I'll probably take it off tomorrow and take it for a spin and see how it reacts.
blackbullet76
posted January 29, 2007 12:20 PM
I removed the screen today. I took it for a ride and it seems fine. I didn't really get on it hard, too dang cold to get any real speed up.
Ojref
posted January 29, 2007 11:16 PM
quote: I removed the screen today. I took it for a ride and it seems fine. I didn't really get on it hard, too dang cold to get any real speed up.
Just wait, it will be weak in the midrange, and knock like hell if the flys are out on WOT launches.
blackbullet76
posted January 30, 2007 04:04 AM
Why would it do all that? The map I have is made for having the screen out. Does it help the engine breathe that much more with it out?
lietoome
posted January 30, 2007 07:49 AM
if the screen is anything like the 12, it seriously impedes the airflow.
posted January 30, 2007 09:19 AM
? Mine is not weak anywhere ...
nightmare
ACP Racing
posted January 30, 2007 05:58 PM
Mine isn't weak as well and that thing came out a long time ago
2006 ZX14 Ninja "SWINE FLU"
60ft 1.23
8th Mile 5.16
ACP Racing
1badzx12r
posted January 30, 2007 06:13 PM
assuming ya'll never ride in the rain
posted January 30, 2007 06:15 PM
quote: assuming ya'll never ride in the rain
Can't drag race in the rain .... So i'm good to go
Nelson Taylor
posted January 30, 2007 07:17 PM
Thanks for reminding me of a mod I need to do.
